when do you guys change timing belt?
Old Jul 11, 2008 | 07:36 PM
hondaville's Avatar
Default when do you guys change timing belt?
civic 2000 ex. thanks
Old Jul 11, 2008 | 07:41 PM
Jakester9500's Avatar
i think it's suggested around every 85k or so.
Old Jul 11, 2008 | 07:43 PM
john666's Avatar
Default Re: when do you guys change timing belt? (hondaville)
depending on how much i love my motor.. usally if its stock if it aint broke why fix it is what i usally go with.. or when the water pump starts going then i do it
Old Jul 11, 2008 | 08:10 PM
ej civic noob's Avatar
Default Re: when do you guys change timing belt? (john666)
i believe honda originally recommended it around 60k miles then they changed to 90k miles
being the honda is an interference engine i would go ahead and do it as a preventative maintenance if its never been done. few hundred bucks in parts and few hrs to do the swap is alot cheaper then having to replace the motor if the belt breaks and you end up toasting the motor
Old Jul 11, 2008 | 09:36 PM
Former User's Avatar
Service manual suggests 105k miles under normal conditions. Under severe conditions, change it earlier.
honda2000vp
15
Oct 11, 2010 09:39 AM
dgdarien
25
Dec 31, 2009 11:18 AM
ashish_bhatta
Oct 1, 2004 12:04 PM
quikrpm'z
Feb 19, 2003 03:14 AM
hobo79
Sep 24, 2001 10:04 PM
