Comments re new set-up
Old Jul 11, 2008 | 10:17 AM
EddieCRX's Avatar
Default Comments re new set-up
I’m interested to hear comments about the new set-up, mainly the modified take off for the Tial on the Neukin and the down pipe with the screamer routed and merged low down.
Being a CRX things a pretty tight at the best of times, extensive modification to the lower panels to make the rad fit, this was made easy due to the tubular front cross member, note, we reinforced the panel were material was removed.
I’m in the processing of changing my build,
Currently running a Sleeved and built B16
HKS Cast Manifold with T35 full 3” system
New
B18 fully built
Neukin Manifold with modified take off for Tial (Hybrid GT30)
Full 3” system
Fluidyne rad and a rather large front mount IC
Old Jul 11, 2008 | 10:24 AM
chimmike's Avatar
looks sweet, but I'd never put my o2 sensor that close to the turbine, IMO.
Otherwise, the fab work looks great, the integration of the dump tube is very nice.
Old Jul 11, 2008 | 02:34 PM
SuperTeg95's Avatar
Default Re: (chimmike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chimmike &raquo;</TD></TR><TR><TD CLASS="quote">looks sweet, but I'd never put my o2 sensor that close to the turbine, IMO.</TD></TR></TABLE>
That's probably a spot for his Wideband, which is a good location for that.
Old Jul 11, 2008 | 02:37 PM
chimmike's Avatar
IIRC you want widebands like 20" from the turbine outlet?
Old Jul 11, 2008 | 03:48 PM
inspyral's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chimmike &raquo;</TD></TR><TR><TD CLASS="quote">IIRC you want widebands like 20" from the turbine outlet?</TD></TR></TABLE>
I think the recommended distance for most of them is something like 12-30" or maybe it was 18-30", I forget.
Old Jul 11, 2008 | 07:29 PM
Tippyman's Avatar
Default Re: (inspyral)
At least 18".
A location that close will be very hot.
Old Jul 12, 2008 | 03:04 AM
EddieCRX's Avatar
Default Re: (Tippyman)
In all honesty, probably not going to use the top port, we have 2 just after the 3 inch flex.
I was a little concerned with the screamer, if it’s too long and the point it merges back into the main system.
Old Jul 12, 2008 | 06:37 AM
SuperTeg95's Avatar
Default Re: (EddieCRX)
Mine has been there for over 3 years and still works great.
Old Jul 12, 2008 | 10:43 AM
I Have an STD's Avatar
wrenchin'
Default Re: (SuperTeg95)
the setup looks great. the wastegate tube is perfect. totally ideal.
KevinEF7
Jan 31, 2016 09:54 AM
Tuner Eddy
Apr 21, 2014 07:31 AM
Tuner Eddy
Appearance Build Threads
Apr 15, 2014 04:49 PM
Tuner Eddy
Apr 13, 2014 03:14 AM
prostreetonline
Jul 27, 2006 02:59 PM
