3 small orings in cylinder block gasket kit
Old Jul 11, 2008 | 03:54 AM
Quade's Avatar
Default 3 small orings in cylinder block gasket kit
One is the bearing cap bridge oil seal what about the other 2? Where do they go?
Old Jul 11, 2008 | 04:02 AM
bluedlude's Avatar
Default Re: 3 small orings in cylinder block gasket kit (Quade)
where did you get the gasket set? theres another small oring that goes on the oil pump that i can think of off the top of my head. maybe the other one is for the dipstick?
Old Jul 11, 2008 | 04:09 AM
Quade's Avatar
Default Re: 3 small orings in cylinder block gasket kit (bluedlude)
bought it from hondaautomotiveparts.com. I changed the oil pump as well and that's true a small oring was on the new one so that eliminates one. now that leaves one more.
Old Jul 11, 2008 | 12:40 PM
Scheizty's Avatar
are they for the oil pressure orifice?
Old Jul 15, 2008 | 02:42 PM
Quade's Avatar
Default Re: 3 small orings in cylinder block gasket kit (Scheizty)
Not that small an o-ring. Remember this is a cylinder block gasket kit.
Old Jul 15, 2008 | 06:13 PM
Altilude's Avatar
I don't know if you are talking about a oil pump one that resides withing the phillip screw section, but just above that, there is one between that whole housing and the block, right below the one balance shaft. - are we talking about the same one?
Old Jul 21, 2008 | 04:53 AM
Quade's Avatar
Default Re: 3 small orings in cylinder block gasket kit (Altilude)
Is there one that goes behind the philip screws on the oil pump as well?? I'm confused. The cylinder head kit also came with a small oring in the plastic bag with the spark plug seals, distributor seal & water outlet seal. What's the other small oring for? I measure it and it about 9.6mm inside diameter and 1.6mm thick. No part numbers on these seals. They came in a plastic bag together that's it.
Old Jul 21, 2008 | 01:46 PM
Scheizty's Avatar
Did you check the dipstick?
Old Jul 21, 2008 | 06:56 PM
Altilude's Avatar
none behind the phillip screws on the pump... but if you are looking at the back of that hole housing (at the phillip screws), you'll notice up and to the left towards the balance shaft hole, there is a little recess for a smallish oring there - that was the one i was originally referring to.
tamboo
Nov 1, 2013 08:41 AM
supracord
May 30, 2011 04:51 AM
sh!ft
Nov 28, 2010 11:30 AM
keychild486
Mar 2, 2009 12:07 PM
Quickridez_3
Apr 30, 2008 09:44 AM
