Passenger Side Air Bag Blockoff's
Old Jul 10, 2008 | 07:49 PM
lude98SH's Avatar
Default Passenger Side Air Bag Blockoff's
First off I only have 1 seat in the car, so there will be no passengers in this seat. Do they make them for preludes or will the EK hatch block off's work ?
Old Jul 10, 2008 | 07:51 PM
dagle's Avatar
Default Re: Passenger Side Air Bag Blockoff's (lude98SH)
why dont u just take the airbag out and put the cover on? isnt that the same thing?
Old Jul 10, 2008 | 07:53 PM
lude98SH's Avatar
Default Re: Passenger Side Air Bag Blockoff's (dagle)
hmm would it be ? im not sure i have never removed it. So the cover can be removed seperately of the air bag ?
So then what is the point of these block off trays ?
Old Jul 10, 2008 | 07:56 PM
dagle's Avatar
for preludes u can, im sure (because ive done it) for other cars im not sure. the cover for the pass airbag is held in snug with the tabs all around.. just pop em off gently and pop it into the airbag space w/o the airbag
Old Jul 10, 2008 | 07:57 PM
lude98SH's Avatar
ok thanks man.
I know i have to do something so keep that SRS light off. Ill have to dig that up, I know i saw it somewhere.
Old Jul 10, 2008 | 08:10 PM
lude98SH's Avatar
Im reading to use a 4 ohm resistor across the circuit. Can anyone verify this ?
Old Jul 11, 2008 | 10:32 AM
InvaderTrax's Avatar
What year? If it's a 4th gen you can just swap in the 92/93 dash and it'll be cleaner than a blockoff
Old Jul 11, 2008 | 11:19 AM
lude98SH's Avatar
Default Re: (InvaderTrax)
98
Old Jul 11, 2008 | 06:43 PM
lude98SH's Avatar
well i pulled the airbag itself out which is a piece of cake and the dash cover comes off of the air bag and snaps right back into place. The only issue here is what size resistor to run and also that the plug is a male plug therefore u can not just run each end on the resistor into the terminal. What I was thinking was that i need the female end of the plug with alittle wire coming out of each side and soldering the resistor in series.
O and BTW i put the airbag on the scale and it only weighs 8 lbs
Modified by lude98SH at 2:34 PM 7/12/2008
Old Jul 12, 2008 | 10:35 AM
lude98SH's Avatar
Default Re: (lude98SH)
bump
Old Jul 12, 2008 | 08:36 PM
Si Speed's Avatar
Wat about removing the driver airbag? Can you take the bag out and put the cover back on?
Old Jul 13, 2008 | 10:58 AM
lude98SH's Avatar
Default Re: (Si Speed)
im not sure about that
Old Jul 13, 2008 | 11:16 AM
Giant_Bean's Avatar
measure the resistance through the airbag, and find a resistor to match(assuming the bag is not blown of course)
Old Jul 13, 2008 | 11:25 AM
lude98SH's Avatar
Default Re: (Giant_Bean)
Ive thought of that but the problem with that is when u measure resistance the multimeter actually sends voltage through the circuit to measure, and im not trying to have an airbag going off lol
follie gatts
Mar 19, 2011 03:10 PM
724chris
Jul 28, 2010 04:10 PM
johnclaunch
34
Sep 11, 2008 12:58 PM
porter
Nov 27, 2006 09:35 AM
baonest1
May 14, 2003 02:36 PM
