Running VTEC off a shift light? TRUE or FALSE
Old Jul 10, 2008 | 06:08 PM
paton5g's Avatar
Default Running VTEC off a shift light? TRUE or FALSE
I've asked this before here on HT, but I've never really received a solid answer. I've heard through a shop owner who seems to be an expert on "budget" builds. We won't get into much there but anyways...
I don't have a VTEC ECU, and my motor is ready to go. LS-VTEC and it's going into my DC4.
I SHOULD just buy the right ECU, pin my harness and be done with it. But I'm out of money and I just want to drive this thing so...
I have an RPM tach with a shift light. Can I run VTEC off the shift light, set to 5200 using a relay? Does the VTEC ECU contain VTEC fuel maps? Won't a regular ECU compensate for VTEC activation?
So can I do this? True or False?
Thanks guys.
Old Jul 10, 2008 | 06:22 PM
paton5g's Avatar
Default Re: Running VTEC off a shift light? TRUE or FALSE (paton5g)
bump
paton5g's Avatar
bump
please!
Old Jul 11, 2008 | 09:41 AM
illusive's Avatar
You can run vtec off of a shift light, vtec can be activated by a rpm switch, tach, basic vtec controller, ect. I have done it on a old EF back in the day with a autometer tach and shiftlight. But I would suggest saving up a bit more money and get the right ecu for your motor. Yes they do have different timing and fuel maps for when you are in vtec and will run better then just activating vtec.
Old Jul 11, 2008 | 04:35 PM
Tomdata's Avatar
Default Re: Running VTEC off a shift light? TRUE or FALSE (illusive)
Bad idea. Get a chipped ecu and have someone tune it for you. The vtec will activate using the shift light but the tune will be wayyyyyy off.
Old Jul 11, 2008 | 07:08 PM
mtber's Avatar
Default Re: Running VTEC off a shift light? TRUE or FALSE (Tomdata)
Do not run vtec off a shift light. A vtec ecu uses high & low cam fuel & ignition maps for a reason. If you run your vtec off a 12 volt switched source such as a shiftlight you will not be running on the proper fuel & ignition timing maps.
Old Jul 11, 2008 | 07:52 PM
frankiedevil_02's Avatar
Default Re: Running VTEC off a shift light? TRUE or FALSE (mtber)
well my car is bauging out when i try to push on it what you think is wrong wont even burn out
Old Jul 11, 2008 | 11:41 PM
98vtec's Avatar
moderator emeritus
Default Re: Running VTEC off a shift light? TRUE or FALSE (frankiedevil_02)
getting the correct ecu comes to mind
Old Jul 13, 2008 | 06:05 AM
paton5g's Avatar
Default Re: Running VTEC off a shift light? TRUE or FALSE (98vtec)
thanks guys. so what would be appropriate? a p28?
Old Jul 14, 2008 | 10:29 AM
HMTforlife's Avatar
Yea, P28 will work good.
Old Jul 14, 2008 | 10:48 AM
Spunkster's Avatar
Default Re: (HMTforlife)
A p28 will only work good if it has been reprogrammed and tuned for his engine.
crooked muffler
29
Oct 17, 2018 04:54 PM
ls weez
Jul 11, 2006 08:34 PM
ham
Jul 8, 2004 05:58 AM
ImportsCRX
Feb 20, 2004 06:44 AM
4dohs4mohoes
Sep 28, 2002 06:30 PM
