Alot questions on correct parts for my tune up.
I am ordering a bunhca parts for a tune up for my car.
However I seem to be stuck on a few of the part numbers. Also wonderin if I should buy a few misc. parts.
If you guys can take a look at the following questions, and help me out, that would be great.
Question 1: Should I purchase Item number <U>6 - Cover, Leake</U>? Its only $4.22 Just wondering if there will be a need for this or not.
Link 1: http://www.acuraautomotiveparts.net/...UTOR+%28TEC%29
Question 2: Take a look at link 2A. I need to replace the bolts for the upper passenger side motor mount. Acura stripped 1 of them when putting in my new tranny. They didnt feel like replacing it. Therefor I am left with a stripped bolt and nutless. I belive the highlighted Green area must be for Automatic, and the highlighted red area is for standerd. Due to the fact I dont have the metal bracket Number 10 on my tranny. Question is. The part number for the bolts I need look like number 37. However, there is no part number on the standerd one. I highlighted the bolts I need with no number in purple. Link 2B Contains the page with part number descriptions.
Link 2A: http://www.hobby-parts.com/ragejed/2a.gif
Link 2B:
http://www.acuraautomotiveparts.net/...5=ENGINE+MOUNT
Question 3: I plan to change my PVC Valve. I read about people changeing it. Just wondering What part numbers I would need to order so I can do this.
Link 3: http://www.acuraautomotiveparts.net/...HAMBER+%282%29
Quesion 4: Seems a line that goes to my fuel filter looks dirty/something in it. I had a friend over and he said that his hose is clear. Please refer to link 4 for more detail including pictures.
Link 4: https://honda-tech.com/zerothread?id=232464
I tried my best to orginize all of this and make it easier to read. Hope it helped.
[Modified by ragejed, 12:59 AM 7/20/2002]
[Modified by ragejed, 1:05 AM 7/20/2002]
Link 2B:
Question 1: Should I purchase Item number 6 - Cover, Leake? Its only $4.22 Just wondering if there will be a need for this or not.
Even if it doesn't come with one, you don't need to replace it unless it's cracked. I never replaced mine the last time I changed the rotor.
If you still want it, I think I still have a new one rotting in a box somewhere. Just a couple bucks for postage.
BTW, if you're having trouble getting the screw off (which you should buy just in case - but the rotor should come with a new screw), you can take the distributor off by disconnecting the wire harnesses for the TDC/CYP/CKP sensors and removing the (3) 12mm bolts.
You shouldn't have to worry about misaligning the distributor when you put it back b/c it only goes back on one way. Idiot proof...so they say. Just don't try to force it on...should just slip into place.
http://www.acuraautomotiveparts.net/...ISSION+HOUSING
http://www.hobby-parts.com/ragejed/F...010055_JPG.htm
I swear that that's Yoda stuck in his line.
Try seeing if you can squeeze Yoda's head to move it up/down, and to check for density of the Yoda object. Hopefully Yoda isn't a dense object.
thinkbrianthink bu
Nov 22, 2002 04:43 AM
