Tranny fluid...what to use with the Quaife?
I'm thinking 10W-30. Anyone have any pros or cons for synth vs. organic, or something else such as Honda MTF or Redline?
Thanks,
Mike
Thanks,
Mike
Try it!
Here is what I did. I have a ZC LSD (clutch-type) and have been having lots of problems with excessive grinding of the friction disks. I put in just over a bottle and a half of 'GM Limited Slip Differential Fluid' filled the remainder with MTF and now the tranny works better than it ever has. A magical mystery fluid, and it came from GM. Use this if yours is clutch-type or if it is Torsen/Gear-type try 'GM Synchro-mesh Fluid' with your MTF. Just talked with a friend today who put this in his ITR per Acura recommendation. I don't like GM stuff very much but they do make good transmission lubricants.
-Taken from Joel Y.
[Modified by bb6h22a, 4:05 PM 7/19/2002]
-Taken from Joel Y.
I just had a Quaife installed in my 2WD 91 Honda Civic Wagon. I had the same question. The answer I got from Quaife was to go with the same oil I had been using before. I've got 8000 miles on it now and have had no problems. Their phone number is 949-240-4000.
same goes for Kaaz LSD's
-Taken from Joel Y.
-Taken from Joel Y.
I'm voting for Honda MTF. If you want to try something more "exotic", then try the Synchroshift... I believe most of the DSM specialty shops will carry it.
