FS: B18A1 Part out , ECU, Evo Injectors Mounts, Electronics
Old Jul 8, 2008 | 10:10 AM
Spoolind16's Avatar
Default FS: B18A1 Part out , ECU, Evo Injectors Mounts, LS Crankshaft!
Price: All prices are obo (unless otherwise noted)
To make a long story short my buddy is parting out his b18a1 (except for the block itself). If you need a part thats not listed he probably has it so just ask via email: kzarembo@twmi.rr.com
All shipping will be at additional cost to the buyer; I accept money order only. For feed back please see my ebay account: tomleez
-----or--------
visit this link: http://www.xceedspeed.com/foru...=2810
NOTE THAT I DO NOT CHECK PM'S ONLY EMAIL.
MAKE SURE TO CHECK BACK OFTEN, I'LL BE ADDING PARTS AS WE DISASSEMBLE THE BLOCK.
LS (b18a1) crankshaft: $100 firm
B18A/B oil pan tapped for turbo. Includes fitting: $40
B18A/B oil pump: $30
B18A/B windage tray/oil baffle: $10
B18A/B water pump only about 3000k miles on it: $35
Chipped P75 ecu: $75
Stock Honda injectors 240cc: $30
b18a1 fan temp switch almost brand new: $5
b18 hydro clutch disc. Its an ACT street strip disc with about 20k miles, still grabs great! $30
Evo 8 560cc injectors: $150 (firm)
b18a1 head. About 118k miles on it. Complete except for, dizzy, fuel rail/injectors. $175
Two Mint condition Steelie rims. 14inch 4x100 $15
Curise Control Unit from a civic : $10
Power Steering Pump for Civics/Tegs $30
Vibrating mounts (lower mounts) for B series (I have both sides) $30 each
Downpipe support: $5
Intake Manifold lower rear bracket: $5
Civic (d series misc) brackets, I know one if for power steering: $10 each
Assorted engine mount brackets: The top three are 2 bolt to the block and 2 bolt to the mount, the bottom is from a DA rubber mount is included: $15 each
D series Waterpump/Thermostat Pipe: $10
Boss Audio DVD player: $15
Modified by Spoolind16 at 12:50 PM 7/14/2008
Modified by Spoolind16 at 6:57 PM 7/15/2008
Old Jul 9, 2008 | 09:07 AM
Spoolind16's Avatar
Default Re: FS: B18A1 Part out , ECU, Evo Injectors Mounts, Electronics (Spoolind16)
bump
Old Jul 9, 2008 | 09:09 PM
Spoolind16's Avatar
late night bump
Old Jul 10, 2008 | 12:48 AM
JWhonda_ride's Avatar
pm me with details on the ecu. P75 is obd1 ls ecu right?
Old Jul 10, 2008 | 04:55 PM
Spoolind16's Avatar
Default Re: FS: B18A1 Part out , ECU, Evo Injectors Mounts, Electronics (JWhonda_ride)
pm'd
Old Jul 11, 2008 | 12:35 PM
Spoolind16's Avatar
ttt
Old Jul 12, 2008 | 10:08 PM
Spoolind16's Avatar
up
Old Jul 13, 2008 | 11:32 AM
Spoolind16's Avatar
ttt
Old Jul 14, 2008 | 08:50 AM
Spoolind16's Avatar
bump for crankshaft
Old Jul 15, 2008 | 03:08 PM
Spoolind16's Avatar
up
Old Jul 16, 2008 | 07:09 AM
Spoolind16's Avatar
ttt
5speeder
Oct 30, 2011 10:37 AM
under_psi
Oct 18, 2004 11:00 PM
onetwothree
Mar 30, 2003 03:00 PM
