engine knocks until oil light goes off?!? what the hell!
Old Jul 8, 2008 | 04:56 AM
LS AzZkIkr's Avatar
Default engine knocks until oil light goes off?!? what the hell!
like the title says, the motor is a rods and pistons lsvtec. the bearings were within spec and i cant figure this out! a friend told me it might be dry start up but i had an engine do this before and was fine until i over revved it. please help this is frustrating me
Old Jul 8, 2008 | 07:34 AM
LS AzZkIkr's Avatar
Default Re: engine knocks until oil light goes off?!? what the hell! (LS AzZkIkr)
bump
Old Jul 8, 2008 | 08:12 AM
Furyof4's Avatar
Did you replace the oil pump when you built the motor? Has it always done this or is it a new problem?
Old Jul 8, 2008 | 09:06 AM
koczeka's Avatar
rod bearing failure... IMO
Old Jul 8, 2008 | 10:41 AM
LS AzZkIkr's Avatar
Default Re: engine knocks until oil light goes off?!? what the hell! (Furyof4)
I bought a oil pump that had 10k on it and cleaned it out. it just started doing this about a week ago. I just also changed to oil and there was no metal on my magnetic drain plug. It did not make that sound after i changed to oil but the next day it did. It only does this until the light goes off and runs perfect.
Old Jul 8, 2008 | 12:52 PM
mar778c's Avatar
Community Builder
Community Influencer
sounds like a spun rod bearing.
Old Jul 8, 2008 | 01:53 PM
projectTeG's Avatar
cut the filter open and inspect. also the check valve in the pump can be going bad.
Old Jul 8, 2008 | 03:18 PM
DonF's Avatar
Default Re: (projectTeG)
Unhook the light and see if the noise goes away.
Old Jul 8, 2008 | 06:43 PM
non-VTEC's Avatar
Default Re: (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Unhook the light and see if the noise goes away. </TD></TR></TABLE>
LOL.......nice
Old Jul 8, 2008 | 06:46 PM
non-VTEC's Avatar
you say the bearing are within spec? is this at time of engine assembly or did you actually pull the oil pan off and check them after you abused the crap out of it?
the specs at time of engine assembly will change when you overheat/spin or flatten a bearing.
pull your oil pan and check the mains and rods.
Old Jul 9, 2008 | 04:26 AM
LS AzZkIkr's Avatar
Default Re: engine knocks until oil light goes off?!? what the hell! (non-VTEC)
I plan on tearing it down soon. I still dont understand why it only does it when its cold? That part doesn't make sense.
Old Jul 9, 2008 | 10:00 AM
SIXTY's Avatar
Default Re: engine knocks until oil light goes off?!? what the hell! (mar778c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a spun rod bearing.</TD></TR></TABLE>
x2. I had the same problem, only made that sound at start-up. Pulled my oil pan and half of my bearing was sitting in it.
Old Jul 9, 2008 | 10:27 AM
tampabitches's Avatar
i had that same problem with an ls when i tore it apart the bottom end was in perfect condition
Old Jul 9, 2008 | 12:35 PM
LS AzZkIkr's Avatar
Default Re: (tampabitches)
That is what i am thinking. A friend of mine that has been a professional mechanic for several years and he said that it sounds like the bearings are dry on start up and that it is nothing to worry about but i have some money wrapped up in this thing and don't want it blowing up on me.
Old Jul 14, 2008 | 05:17 AM
LS AzZkIkr's Avatar
the knock seems to have gone away.? i replaced my pcv and tightened my timing belt and it has seemed to stopped.
Old Jul 14, 2008 | 09:28 AM
98vtec's Avatar
moderator emeritus
Default Re: (LS AzZkIkr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LS AzZkIkr &raquo;</TD></TR><TR><TD CLASS="quote">he said that it sounds like the bearings are dry on start up and that it is nothing to worry about </TD></TR></TABLE>
that statement worries me.
Old Jul 14, 2008 | 10:13 AM
goforbroke's Avatar
MEAT PATTY
Default Re: (98vtec)
It only started making this noise after you changed your oil? What kind of oil are you running?
spoolin08
Jun 2, 2011 04:40 AM
gloryman_17
Aug 12, 2008 02:59 AM
LS AzZkIkr
Apr 9, 2007 10:17 AM
b.d.racing
Aug 7, 2006 09:54 PM
DAinfamousR
Nov 19, 2003 07:49 PM
