window net question
Old Jul 7, 2008 | 01:43 PM
92sc61's Avatar
Default window net question
Does anybody know the exact requirements for window nets, specifically IHRA tracks?
I have a 10pt cage in the car and a window net setup facing the outside of the bar (door side). I've been to the track a few times this year and the previous owner used it two years ago with no problem but all of a sudden last time I went they said the net setup needs to be on the inside of the bar which is rather difficult considering the sparco seat i have sticks over top of the bar. Anybody else have issues like this?
Old Jul 7, 2008 | 01:47 PM
nonvtecallmotor's Avatar
Default Re: window net question (92sc61)
The window net must be on the inside of the bar.
Old Jul 7, 2008 | 03:03 PM
jjspec's Avatar
Default Re: window net question (rota92)
The theory is that if the body is completely ground away and all the is left is the roll cage, the window next needs to still be intact. That is how it was explained to me by a NHRA tech official. Hope that helps.
Old Jul 7, 2008 | 03:49 PM
92sc61's Avatar
Thanks for the answers guys. I don't know how it's going to get done with the seat I have but I'll take it to the shop to have a look see.
Old Jul 7, 2008 | 04:24 PM
jjspec's Avatar
Default Re: (92sc61)
If the seat sit over the top of the bar you may have issues to start with. If you go with an aluminum seat it will probably weigh a little less and fit a little better. Good luck everything.
Old Jul 7, 2008 | 08:41 PM
redboost10's Avatar
Default Re: (jjspec)
i had some pics to share
Old Jul 7, 2008 | 11:41 PM
rip94delsol's Avatar
Default Re: (redboost10)
On my cage the bottom mount is on top of the bar using 2 tabs and the top mount on the inside with a seatbelt buckle as a means of attachment.
Old Jul 8, 2008 | 01:37 PM
SPOOLINmatt's Avatar
Default Re: (rip94delsol)
my buckle is pretty much inline with the bars, more to the outside then center though. Ive ben teched by NHRA sport Compact tech people, NDRA, and some ******* tech guys at the atlanta drag way and never really been bothered about it. theres really no way you could crash the car and it rub all the sheet metal away where theres just a roll cage showing. Not unless you are going 300 mph sliding down the track on its side in some miracle accident. Im going to redo it to make sure its within the cage for next year as im getting Kirkey seats. I know what you are talking about with the seat hanging out.
Old Jul 16, 2008 | 02:56 PM
92sc61's Avatar
Sorry to bring this up again, but does anybody have pics of how they did their lower tabs? I found the upper tab I need on g-force and looked elsewhere for the lower tabs but can't find anything.
They don't look like they were fabricated so I'm guessing they were bought from somewhere but I have no idea. Or is there a kit you can buy from somewhere that doesn't require lower tabs like redboost10 has above?
Old Jul 16, 2008 | 04:07 PM
boostedcivicsir's Avatar
Mr. Badwrench
mine is basically a tube through the net and welded under the bar if that makes sense.
Old Jul 16, 2008 | 04:28 PM
AllmotorEH2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redboost10 &raquo;</TD></TR><TR><TD CLASS="quote">i had some pics to share
</TD></TR></TABLE>is that really a piece butt welded on your main hoop right above the door bar or is that just some slim padding?????????
Old Jul 16, 2008 | 04:31 PM
redboost10's Avatar
Default Re: (AllmotorEH2)
haha, thats padding. i see where your coming from though
Old Jul 17, 2008 | 02:35 AM
boostfeen's Avatar
Default Re: (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">
...nice steering wheel cover Mikey
Old Jul 17, 2008 | 02:46 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92sc61 &raquo;</TD></TR><TR><TD CLASS="quote">Sorry to bring this up again, but does anybody have pics of how they did their lower tabs? I found the upper tab I need on g-force and looked elsewhere for the lower tabs but can't find anything.
They don't look like they were fabricated so I'm guessing they were bought from somewhere but I have no idea. Or is there a kit you can buy from somewhere that doesn't require lower tabs like redboost10 has above?</TD></TR></TABLE>
mine is like Mikeys but on the top of the tube.
a small version of this tab would work fine. the size bolt in there i belive is a 10-32. (holding the lower window net tube to the tab/cage)
Old Jul 17, 2008 | 02:52 AM
Mr. Badwrench
Default Re: (boostfeen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostfeen &raquo;</TD></TR><TR><TD CLASS="quote">
...nice steering wheel cover Mikey </TD></TR></TABLE>
i knew someone would pick that out.
they actually put that on to protect the wheel.
vectorsolid
22
Aug 2, 2012 12:36 AM
tom_l
21
May 10, 2004 04:22 AM
1 2 NV
Mar 17, 2004 07:52 PM
ImprtTuner88
Oct 10, 2003 06:15 PM
Ideal
Oct 17, 2002 06:49 AM
