looking for 92-95 cx/vx bin that i can use in a p05 dx ecu
Old Jul 7, 2008 | 12:11 PM
dem0nk1d's Avatar
Default looking for 92-95 cx/vx bin that i can use in a p05 dx ecu
guys is it possible to rip the stock cx/vx maps and lay it over a p30 rom so i can have datalogging, 5 wire o2 sensor running. I'm no way doing this for a preformace gain, more or less for saving gas. The motor will be d15b7
Old Jul 7, 2008 | 03:56 PM
mtber's Avatar
Default Re: looking for 92-95 cx/vx bin that i can use in a p05 dx ecu (dem0nk1d)
The p05 ecu doesn't have wideband control hardware in it so you won't get wideband lamda feedback without making some kind of controller etc.
Eprom editors on the market now don't support p07 ecus or codebase.
Your best bet is to use a p05/p06 base bin & copy the fuel/ignition values over to a p30 rom with vtec disabled, then tune the car using a wideband etc.
Old Jul 7, 2008 | 08:36 PM
dem0nk1d's Avatar
that's what i run now p05 dx base maps on the top of a p30 map. so i can datalog etc...
Old Jul 8, 2008 | 01:08 AM
mtber's Avatar
Default Re: (dem0nk1d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d &raquo;</TD></TR><TR><TD CLASS="quote">that's what i run now p05 dx base maps on the top of a p30 map. so i can datalog etc...
Your good to go, simply tune the fuel & ignition tables just like you would any other motor.
PointA2B
23
Mar 2, 2007 10:07 AM
stockcivic103
17
Feb 20, 2006 08:31 PM
mrtrex
Oct 11, 2005 06:34 PM
pagong
Oct 18, 2003 03:30 PM
civicmatt
Feb 12, 2003 09:19 AM
