95 dx ecu in a 95 cx?
Old 02-10-2003, 01:27 PM
civicmatt's Avatar
Default 95 dx ecu in a 95 cx?
I want to know if a dx ecu will work on my cx motor? They are both from 95 and my cx ecu is giving me problems. Has anyone else done this? Thanks.
Old 02-10-2003, 01:34 PM
VTECVillain's Avatar
Default Re: 95 dx ecu in a 95 cx? (civicmatt)
Yes but you will need a DX O2 sensor. The DX has a 4 wire and the CX has a 1 wire O2 sensor. It will throw a CEL if you don't use the one for a DX.
Old 02-10-2003, 02:54 PM
civicmatt's Avatar
Default Re: 95 dx ecu in a 95 cx? (VTECVillain)
will the dx o2 sensor plug right into my factory harnesss by the distributor? Or do I need to run all new wires to my ecu? Thanks.
Old 02-10-2003, 03:09 PM
You will need to run new wires. By the way, why are you wanting to use the DX ECU?
Old 02-11-2003, 07:05 PM
civicmatt's Avatar
I'm swapping on a dx head with crx si cam and I'm setting it up like mista bone. I want to know if I can hook up the dx ecu while still running a cx head. I'm just curious as to what would happen. Maybe I'll feel a difference. Thanks for your help.
Old 02-11-2003, 07:10 PM
I would go straight to the source and get the info from him. There should be no reason why the ECU wouldn't work with the setup you plan to run. Like I said before though, just make sure to use a DX O2 sensor and wire it up correctly.
Old 02-12-2003, 09:19 AM
civicmatt's Avatar
I don't have a dx o2 sensor yet, but don't I just plug it into the harness where the cx sensor came from? Or do I have to run wires to my ecu? Will the car run fine with a cx sensor, at least until its inspection time? Thanks.
PointA2B
23
03-02-2007 10:07 AM
stockcivic103
17
02-20-2006 08:31 PM
phatcivic99
05-05-2003 04:36 AM
Civmochris
11-11-2002 07:35 PM
95cx
04-21-2002 07:54 AM
Quick Reply: 95 dx ecu in a 95 cx?
