Seat Height : Sedan vs coupe/hatch????
Old Jul 7, 2008 | 05:36 AM
xXx Justin xXx's Avatar
Default Seat Height : Sedan vs coupe/hatch????
For some reason, sitting in my 94 ex sedan, the stock seats seam to feel higher up than the stock seats in a hatch. Is this the case? And if so, is it the seat brackets or the actual seat bolt location in the floor pans?
From what I could find searching, people say integra seats sit a touch higher in their hatches vs stock. I sat in a friends hatch with 2000 LS seats (which have a height adjustment), then sat in my stock sedan seats, and I felt like the sedan was up higher. Is this just b/c of the 2000's having the height adjustment, or are the sedan seats positioned higher?
Just looking for a little truth before I do a 4dr integra seat swap (front and rears).
Modified by xXx Justin xXx at 8:05 AM 7/8/2008
Old Jul 8, 2008 | 04:04 AM
Default Re: Seat Height : Sedan vs coupe/hatch???? (xXx Justin xXx)
Anybody?
Old Jul 8, 2008 | 05:06 AM
davefromPA's Avatar
the sedan seats are higher. im not sure why. i will have to look at my two cars but i know for sure the sedan seats are higher. if your switching to teg seats you will notice a drop in height from your sedan seats.
Old Jul 8, 2008 | 07:12 AM
Default Re: Seat Height : Sedan vs coupe/hatch???? (davefromPA)
So it is the actual sedan seat itself, not the mounting location in the floor pan. Thats good to hear. I dont have any stock coupe/hatch seats to compare rails/seats against to answer this question. If I did I would take a vertical measurement from the floor to the top of the bottom cushion, then put the coupe/hatch seat in the sedan and measure. with the seats in the same slide position. all the way forward or all the way back.
be a good way to have a solid answer for anybody searching in the future..
Old Jul 8, 2008 | 10:00 AM
davefromPA's Avatar
good point. ill do that tonight with the measurements. right after work.
Old Jul 10, 2008 | 03:27 AM
Any updates? Wondering if you had the chance to do that research. Or if anybody else reading may know...
Old Jul 10, 2008 | 04:45 AM
davefromPA's Avatar
did it and forgot the numbers already. gonna do it again and let you know. give me a day and ill have it for you.
Old Jul 21, 2008 | 04:30 AM
Anybody else out there have the ability/means to test this with solid numbers for future reference? Thanks
Old Jul 22, 2008 | 08:35 AM
Please??
boxeocampeon
37
Feb 20, 2010 12:59 PM
StockEm2
Jun 16, 2009 11:35 AM
Frost7177
Dec 2, 2008 11:49 AM
Essenar83
Jun 7, 2006 04:00 PM
albert
Feb 24, 2004 04:24 PM
