ATF in gastank
i heard that if injectors are clogged then run half bottle of ATF in gas tank with a half tank of gas and a full bottle with a full tank and it will clean out the injectors really good, any truth to this or what?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrianFreels »</TD></TR><TR><TD CLASS="quote">i heard that if injectors are clogged then run half bottle of ATF in gas tank with a half tank of gas and a full bottle with a full tank and it will clean out the injectors really good, any truth to this or what?</TD></TR></TABLE>
never heard that one before. Just get a bottle of injector cleaner its cheep and is less likely to screw things up. I do know of people that sub a bottle of atf for oil when they change their oil.
Yikes. Haven't heard that one before. Just get a good injector cleaer and if your still not happy send them somewhere to be cleaned like http://www.xenocron.com.
From: Where the wild things are in, NY, United States of America
Me thinks you hang out with the triangle worshippers (rotary heads) too much. ATF is commonly used among higher mileage rotarys to help the apex seals hold out (run a bit in the motor and then drain and refill with regular oil), but i've never heard of it doing anything for fuel or the like.
Moral of the story? Don't do it.
get a decent fuel injector cleaner or send them to xeno to get a real cleaning.
ive heard of old school as v8 gas doing this for alot of different reasons but theres no point nowadays.
lv6l
Oct 16, 2005 10:17 AM
