seafoam...
seafoam...
i tried posting in the older seafoam forums but it kept on saying error. i just wanted to know how much of gas i should have if i was to pour 1/3 of seafoam into my gas tank?
Re: seafoam... (hatch_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch_ »</TD></TR><TR><TD CLASS="quote">i tried posting in the older seafoam forums but it kept on saying error. i just wanted to know how much of gas i should have if i was to pour 1/3 of seafoam into my gas tank?</TD></TR></TABLE>
1/2 of can in gas tank other 1/2 in crank case oh and do this on full tank i like to run my car around the block real quick
then do the oil change process!
Re: seafoam... (richard7968)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richard7968 »</TD></TR><TR><TD CLASS="quote">
then do the oil change process!</TD></TR></TABLE>
Misinform more?
Supposed to be 1/3 in crankcase, 1/3 in a vacuum line, and 1/3 in fuel tank. And with the fuel, I'd do it when you're almost empty, then fill it right up (just like any other fuel injector cleaner).
With the crankcase, change the oil immediately after driving it for a bit (I'd say 25-50 miles).
With the vacuum line, just make sure you let it sip it and don't just pour it down. And don't let the car die out. Sip, let the idle go back up, sip, let the idle go back up, etc. until it's all in. It's also easier to have someone else help you by pressing on the gas to prevent the car from dying.
Misinform more?
Darth ModerVader
That's what I do. Treat it like regular fuel injector cleaner. Not like sputtering-almost-empty-and-close-to-having-to-push-you-car-into-the-gas-station close. But yeah just near empty.
Not sure if it really matters but fuel injector is used that way so that's what I've always done.
Re: seafoam... (amej8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amej8 »</TD></TR><TR><TD CLASS="quote">
Misinform more?</TD></TR></TABLE>
how is that misinform?
that is how i have always done it and has been fine for me?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">http://www.seafoamsales.com/motorTuneUpTechGas.htm </TD></TR></TABLE>
says right here the same crap!
does this stuff also clean the valvetrain as well when ran through the crank case or fuel injectors? i seen it takes care of pings and ticks and little noises. but really this stuff work?
litterbox
28
11-04-2005 07:36 AM
lv6l
10-16-2005 10:17 AM
