Relay problems, pls help.
Rpm,tach, fuel, temp needle all dead. Both signal not functioning and clock not working either. Hazard light switch is ok and none of my fuse blown I've checked at kick panel. I think it a relay somewhere that out. Anyone know of what the problem were and where I could checked
Car running perfectly fine, all dome light, climate, blower were good.
Anyone know of a problem like that. Where could I check???
what year is your car? I checked the circuits for 95-97 civic and could not find any relays common to the issues your having. only thing is the connection to the gauge assembly. I'm sure you checked the fuses under hood.
Yes I've checked fuses under the hood, nothing found. It a 93 civic coupe si.. Well it happen after the fuel didn't prime when ignition on, so i tap the fuse panel for bug and then this happen. Anyone know where the main relay for cluster or something. Or anyrelay I could look into to filter the problem?.
It very weard that just all needle on dash went out and all units function normal. I could of thought it the cluster itself, but light and dimmer were still on and it cant just pop broke all unit in a flash. Could it..
Modified by Turbo-Honda at 10:15 PM 7/8/2008
curiousgpnoy
13
Sep 4, 2010 12:31 PM
willyd88
Nov 7, 2005 07:06 PM
