civic d16z6 k26 turbocharge smoke???????????
Old Jul 6, 2008 | 05:36 PM
tonylor89's Avatar
Default civic d16z6 k26 turbocharge smoke???????????
hi i have a k26 turbo in my car which is a a civic with d16z6 and it has oil on the downpipe exhaust.....i was wondering if you guys can help out......maybe a turbo seal or something...ohh yeah i have smoke at my exhaust too....when i'm at moving speed n at like 3 thousand rpms there is no smoke but if at normal idle it smokes kind of alot...please u guys help me think of wat it might be thank you
Old Jul 6, 2008 | 05:41 PM
turboteg90's Avatar
pm for noodz
Default Re: civic d16z6 k26 turbocharge smoke??????????? (tonylor89)
take the turbo off and see if it still smokes
Old Jul 6, 2008 | 05:49 PM
jdmboss's Avatar
Default Re: civic d16z6 k26 turbocharge smoke??????????? (turboteg90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboteg90 &raquo;</TD></TR><TR><TD CLASS="quote">take the turbo off and see if it still smokes</TD></TR></TABLE>
lol wtf!
Old Jul 6, 2008 | 06:04 PM
tonylor89's Avatar
Default Re: civic d16z6 k26 turbocharge smoke??????????? (jdmboss)
no the cra does not smooke.......
Old Jul 6, 2008 | 06:15 PM
D16SiHatch's Avatar
if oil is visible then its very likely that the turbo seals took a **** on you. my friend has had many go on his various turbo engines. If you actually see pools of oil its pretty much a dead giveaway, because if there was that much oil puking out of your engine, it would be a paper weight by now
Old Jul 6, 2008 | 07:13 PM
tonylor89's Avatar
Default Re: civic d16z6 k26 turbocharge smoke??????????? (D16SiHatch)
well it's actually not having pools of oil it just smokes throught the exhaust and has like some oil on the down pipe where it connects to the turbo....so it might be a turbo seal leak???
Old Jul 7, 2008 | 03:39 AM
nekoabandoned's Avatar
take the turbo off and run without it, did you buy it boosted or did you do the build?
if you did the build yourself you should still have the stock manifold , switch out the turbo and see if she smokes anymore.
if there was oil leaking from the cartrage the turbo would have seized.
Old Jul 7, 2008 | 11:20 AM
tonylor89's Avatar
Default Re: civic d16z6 k26 turbocharge smoke??????????? (nekoabandoned)
it's off from an audi turbocharged.....it's stock boost....n before i put in the turbo it dosen't smoke but it started whe i put in the turbo....oil is from the part whea turbo n down pipe connects... so i don't knoebut boost kicks tho....n i have a check engine turn on when i floor it to like 5-6 thousand rpms ...
sasinorm01
Dec 6, 2014 03:27 PM
myessay
Jan 27, 2012 01:59 AM
tonylor89
Jul 11, 2008 07:43 PM
luv2boost
Jul 6, 2007 05:01 AM
integracivic94
Jan 8, 2005 01:03 PM
