96 accord expert wanted...help
so i did a full tuneup (oil, filter, fuel filter, plugs, wires, cap, rotor, checked for a clogged cat, cleaned air filter, checked vacuum lines, checked for codes and hooked up a obd 2 scantool a pretty expensive one. and my car still wont rev up also has good fuel pressure.. it wil go to redline if i gradully accelarate but if i give just a little to nuch throttle it bogs down and falls on its face.. and backfires through the intake a lil please help.../????DISTRUIBUTOR OR MAYBE COIL ?????? no engine lights at all what could it be and how can i test this 96 ex f22 vtec
I'm far from an expert, but just wanted to throw this out there.
Check your sensors, crank sensor, o2 sensor, and your pcv.
That is a really odd problem, was it doing this before the tune-up?
You probably checked but make sure your fuel filter isn't on backwards.
Someone on here can def help you.
Good luck with it.
Nick
Good luck with it.
Nick
thanks it started doing it bout a month after the plugs and cap ,rotor, so i changed the feul filter and wires and it still does it.... does it throw a code if any of the sensors arent working properly. ive took this car to a bunch of backyard mechanics and everyones stumped. even to the deisel mechanic at our shop and no clue what it could be.
yeah anything more than just enough to make it excellerate.. it just pops and sputters but no engine light. the otherday it died so i hopped out with an extra plug to check if it had spark and it did.... so i thought it was a fuel problem so i grabbed a can of starting fluid and sprayed it in and it still wouldnt fire.. thats why im leaning toward distributor.but it cost$$$$ just to change and it still have the problem.. maybe not getting enough spark under excelleration or a load like up a hill
Well i know from the boneheads on cartalk that a weak coil will let the car idle and run fine at low RPMs, but under load there's not enough time to charge the spark plugs with a good hot spark.
Give me a pm with your email address and I'll send you info on how to test the resistance and stuff with an ohm meter.
thats what i was thinking i had a gsr coil go out and did the same thing for about an hour then go all the way out. this has been going on for about 2 weeks of driving. so i was hoping it would just die pmed email thanks
i tested the coil with an ohm meter reading kept jumping around but it was close to what it should be so i went and bought a coil anyway and that was the problem yay
thanks for everyones help
joaodossantos
Jun 9, 2007 08:18 PM
SlalomHonda
14
Nov 21, 2005 06:53 AM
barkwaffle
Jun 2, 2005 10:09 AM
