ECU Throwing Code 19: Automatic transmission lockup control valve
you know whats funny... i have the same problem...
https://honda-tech.com/zerothread?id=2268754
still cant figure it out... >.<
Wow, I have the same problem. I hate it and I just ordered a P28 ECU chipped with Hondata S300 hoping it would fix the problem. Idk, bump this up so we can figure out what the hell is going on with this...
being chipped isnt going to help you you have to do a auto to man conversion inside the ecu ...kinda like chipping but not
im shure theres a writup somewhere if your down with soldering if not i reccomend having it done for you or finding a man ecu...dont just look at the sticker on the case look on the accual pcb so you know it wasnet just switched
No, what I did was I ordered a new ECU completely. I really didn't feel like going through all of the trouble of chipping it myself. My ECU code is 37820-P30-900. I don't know what that means, but I'm sure someone does...
If I recall correctly, p28 ecu's made for automatic transmissions are equipped with a resistor sitting underneath the ROM. I remember reading (a few years ago) that this resistor has to be removed and the nodes that connected it shorted in order to avoid Code 19 in a manual car.
Is this correct? If so, does anyone know the resistor that needs to be removed?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jax97hx »</TD></TR><TR><TD CLASS="quote">it means you have a automatic ecu in your car...</TD></TR></TABLE>
while this would make sense... but the ecu in my car ISNT an automatic...
crnimacak
Dec 31, 2005 04:30 PM
baonest1
Mar 19, 2003 07:06 AM
JDM CRX
Jul 22, 2002 04:54 AM
