What kind of head gasket should I buy?
Old Jul 6, 2008 | 08:36 AM
Cleft_Asunder's Avatar
Default What kind of head gasket should I buy?
I have a blown headgasket on my stock DX (118K miles). It's leaking radiator fluid through the passenger side. The previous owner didn't take care of the cooling system. They put water in it instead of radiator fluid in LA, and it was all rusted out. I was able to flush the system and didn't have to replace anything but a few hoses, but it seems the HG has gone.
I want to replace it with an MLS HG with ARP bolts, but I don't know what manufacturer to buy from. Felpro, cometic, et cetera.
Old Jul 6, 2008 | 08:46 AM
vtecb18c's Avatar
Default Re: What kind of head gasket should I buy? (Cleft_Asunder)
its a stock dx just get one through honda
Old Jul 6, 2008 | 08:48 AM
hotrod99's Avatar
Default Re: What kind of head gasket should I buy? (vtecb18c)
yeah just get an oem honda gasket
Old Jul 6, 2008 | 09:07 AM
BuiltforSin's Avatar
OEM ftw.
Old Jul 6, 2008 | 09:12 AM
spivt11's Avatar
* B A N N E D *
Since your engine is stock if I were you I would save my money and buy oem head gasket and oem head stud bolts.
Old Jul 6, 2008 | 09:13 AM
Default Re: (mugenej8power)
Thanks but I'm just worried that I will have to do this again. The stock HG seems weak. I don't know...
Yes, it's a stock DX, I don't race.
Old Jul 6, 2008 | 09:43 AM
Yeah, I will have it checked at a machine shop. Do I have to add a sealant to the gasket? http://cgi.ebay.com/ebaymotors...ZWD1V
Old Jul 6, 2008 | 09:44 AM
BlackDeuceCoupe's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cleft_Asunder &raquo;</TD></TR><TR><TD CLASS="quote">I don't know what manufacturer to buy from. Felpro, cometic, et cetera.</TD></TR></TABLE>
Can't go wrong with Felpro, IMHO!
Torque it once and that's it...
BTW, make sure your block and head are flat!
A blown HG is usually indicative of a more serious underlying problem - they don't blow for no reason...
Old Jul 6, 2008 | 09:51 AM
Default Re: What kind of head gasket should I buy? (BlackDeuceCoupe)
Here is a pic of my HG and where I think it's blown. Does it look normal?
http://i199.photobucket.com/al...7.jpg
Old Jul 6, 2008 | 10:03 AM
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cleft_Asunder &raquo;</TD></TR><TR><TD CLASS="quote">Here is a pic of my HG and where I think it's blown. Does it look normal?</TD></TR></TABLE>
Hard to say...
You gotta take it apart and use a machinist's ruler and feeler gauges to see if the deck and head is flat.
Old Jul 6, 2008 | 11:12 AM
vtecb18c's Avatar
yea if your drove with it shot than its possible the head is warped
Old Jul 6, 2008 | 11:53 AM
4drkidd's Avatar
Felpro never did me wrong..
Old Jul 6, 2008 | 12:31 PM
SOHCEK-Turbo's Avatar
Default Re: (4drkidd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cleft_Asunder &raquo;</TD></TR><TR><TD CLASS="quote">Thanks but I'm just worried that I will have to do this again. The stock HG seems weak.
Yes, it's a stock DX, I don't race.</TD></TR></TABLE>
Lol!!!
Just go stock HG and Studs. You dont need any aftermarket on stock engine unless you are a ricer and whant to brag to your friends that you gained 50hp because you have a Cometic HG. Get a y8 from a 96-00 EX enginehead gasket which are about $35 much cheaper then any other engine at Honda from what I understand. I always re-surface my heads just to be safe so maybe its not a bad idea if you do it.
Old Jul 6, 2008 | 01:21 PM
HT White Ops
Default Re: (SOHCEK-Turbo)
Are OEM gaskets MLS?!?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cleft_Asunder &raquo;</TD></TR><TR><TD CLASS="quote">I want to replace it with an MLS HG...</TD></TR></TABLE>
@ OP here's a Felpro for 44 bones...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cleft_Asunder &raquo;</TD></TR><TR><TD CLASS="quote">Do I have to add a sealant to the gasket? http://cgi.ebay.com/ebaymotors...ZWD1V</TD></TR></TABLE>
This is the **** you'll want!
Old Jul 6, 2008 | 04:08 PM
B20EF's Avatar
^^^Make sure the copper spray can go with whatever head gasket you buy. It does not mix with Cometic head gaskets, I learned that the hard way by blowing it after only 100km's.
mooneyestwo
Oct 7, 2014 10:14 AM
JDMCivic95EG
Apr 29, 2014 12:17 AM
vedocustoms128
Apr 7, 2012 12:59 PM
Joeski99Si
Apr 23, 2009 05:24 AM
panda_eh2
Dec 12, 2007 01:35 PM
