Will i need larger pistons when i hone my block because of a spun bearing?
Old Jul 6, 2008 | 08:25 AM
white4doorsi's Avatar
Default Will i need larger pistons when i hone my block because of a spun bearing?
Do i even have to hone the block after i remove the piston?
If i do have to hone the block will i have to use bigger pistons or can i use stock ones?
The motor is a stock B18C1
Old Jul 6, 2008 | 08:51 AM
hotrod99's Avatar
Default Re: Will i need larger pistons when i hone my block because of a spun bearing? (white4doorsi)
if your just honing the block you'll be fine using the stock size pistons
Old Jul 6, 2008 | 09:04 AM
all-mtr-teg's Avatar
You will need to go overbore if the cylinders are out of round beyond spec.
Old Jul 6, 2008 | 09:34 AM
pleej's Avatar
Default Re: Will i need larger pistons when i hone my block because of a spun bearing? (all-mtr-teg)
if youve spun a bearing i would rebore 0.5 and go with a 81.5 piston
Old Jul 6, 2008 | 12:32 PM
Street Rice's Avatar
Default Re: Will i need larger pistons when i hone my block because of a spun bearing? (pleej)
My take... if the sleeves are perfectly fine, rebuild the spun bearing (replace the rod that is spun and the crank. Replastigauge everything with the new crank u will be using, reclock the piston rings and reinstall everything back in your old block. If you spun a main bearing then thats a different story.. id look for a new block if that was the case
Old Jul 6, 2008 | 01:05 PM
no just a rod bearing was spun the mains are great. I just didnt know if a hone was necessary or not. Having to hone up a size then get new pistons and rods gets costly
cityofcaterpillars
Engine Machining & Assembly
Jul 19, 2016 05:10 AM
Comp97GSR
May 18, 2012 07:17 PM
b16bri
Oct 11, 2010 05:39 PM
Rob§
Aug 17, 2010 02:51 AM
metal-x
Mar 4, 2003 12:06 PM
