Boring D-Series question
Old Aug 4, 2010 | 08:28 AM
Rob§'s Avatar
Default Boring D-Series question
Spun a bearing in a block i had bored to 20 over and i have to either A) get a new block and re-bore to 20 over or B) bore original engine 40 over to fit new pistons in
Which whould i do?
Old Aug 4, 2010 | 08:43 AM
Psychoteen101's Avatar
Default Re: Boring D-Series question
If its unsleeved, get a new block and bore it 20 over. Cylinder walls are thin enough in those motors to keep boring it over size. Plus they are a dime a dozen so youd be better off with a new block.
Old Aug 4, 2010 | 09:42 AM
d16y8turbo's Avatar
new blocks are cheap, and you need to get new bearings and stuff anyways.
Old Aug 4, 2010 | 09:54 AM
Rob§'s Avatar
New block it is luckily i have an extra block sitting in my basement, i just need to find a new crank.
Thanks guys
Old Aug 4, 2010 | 12:29 PM
Adriano's Avatar
If you only spun a bearing, why do you need to replace the pistons? All you have to do is replace the crank and/or rod and new bearings.
Adriano
Old Aug 4, 2010 | 01:06 PM
ReDemoN's Avatar
DixielandImports Please
Thats what I was thinking...
Old Aug 17, 2010 | 02:51 AM
Rob§'s Avatar
Because the block did not seize up and metal shavings dug into my Vitara (Cast) pistons which scared the hell out of my clyinder walls. i have to replace the entire bottom end.
spoon93
May 9, 2011 08:15 AM
white4doorsi
Jul 6, 2008 01:05 PM
phyzJunkieCivic
Mar 4, 2006 05:13 PM
preludesi93-arg
Jun 23, 2005 10:46 AM
gsr squirrel
Apr 26, 2002 09:22 PM
