car starting problem
Old Jul 5, 2008 | 01:01 PM
Paintballguy's Avatar
Default car starting problem
I just bought a 94 eg hatch, and I am having a problem getting it started. When I turn the key to start, nothing happens. I hear a click from the main relay, and I dont hear the fuel pump prime. I am thinking its the main relay.
Is there anything else to check?
Old Jul 5, 2008 | 01:04 PM
Rok_Stok's Avatar
Default Re: car starting problem (Paintballguy)
The battery, have you tried jump starting it?
Old Jul 5, 2008 | 01:05 PM
Default Re: car starting problem (Rok_Stok)
That would be a good thing to check.... lol I'm gonna go grab a battery jumper and try it.
Old Jul 5, 2008 | 03:01 PM
well it wasnt the battery...
Old Jul 5, 2008 | 03:03 PM
Pothole987's Avatar
Did you take the cover off too see if the fuel pump is grounded? mine had a problem and the 10mm bolt on the dirvers door post came loose.
Old Jul 5, 2008 | 03:09 PM
rSol93's Avatar
if the fuel pump isn't priming its the main relay
Old Jul 5, 2008 | 03:14 PM
i tried using a different relay with the same results. I don't know for sure if that one is good though. I will check to see if the fuel pump is grounded good.
Old Jul 6, 2008 | 06:53 AM
RideDaEJ2's Avatar
I'm having problems with my ej2 not starting, im not tryin to jack this thread but i figured why open one. This might help you out as well. My Car cranks, but wont start and the check engine light stays on already checked the main relay its not that, i tried a brand new one and it didnt do ****. any ideas? ive heard it might be the ecu.
vtec8200
Jul 16, 2012 03:16 PM
93EssEYE
Jul 12, 2010 11:29 AM
fryman
16
Dec 31, 2008 07:56 AM
tegman23
Jun 18, 2008 07:30 PM
wankerman28
Aug 26, 2007 01:04 AM
