Vacuum leak issues...
Old Jul 5, 2008 | 12:23 PM
car47's Avatar
Default Vacuum leak issues...
Hey folks!
I've got a vacuum leak. I'm assuming it's because with my stupid mini kit, they cut the intake manifold to shorten it, and secured the two halves using silicone intercooler hose and clamps. I can't get at these things without removing the whole motor, so I'm avoiding that for now, and am just dealing with the fact that my idle rotates between 700rpm and 1400rpm ... rollercoaster style. No big deal.
But I'm also having another issue which I'm not sure is related, and I was wondering if you guys could give me some insights and opinions as to the source of this other gremlin.
When I'm on the highway, because of my teeny wheels and 4.7 final drive, I'm doing about 50 / 55mph at 3500rpms in 5th gear. Occasionally (seemingly randomly) when I try to go over 4k rpms, it feels like the ECU cuts power ... feels like it's just shutting the butterfly in the intake; but I know it's cable operated so that can't be happening. What's weird though is that the motor will happily rev to 8k in the other gears (except once it did this while I was accelerating on an onramp and I just lost power). Does this sound like anything related to having a vacuum leak? Is the ECU sensing it and saying "STOP!"?
Very weird. Any help / input / whatever would be greatly appreciated.
Thanks!
- Adam
Old Jul 6, 2008 | 12:42 PM
car47's Avatar
Default Re: Vacuum leak issues... (car47)
bump ... any ideas?
Old Jul 6, 2008 | 01:44 PM
bobjohnson's Avatar
Are you throwing any codes when this happens?
Old Jul 7, 2008 | 07:11 AM
car47's Avatar
Default Re: Vacuum leak issues... (bobjohnson)
At startup, it's throwing a code 11, which as far as I can see, doesn't exist...
But I can't tell if it throws a separate code while I'm driving and the power failure occurs. I'll try to check that out.
Jspeedrifter
Sep 11, 2007 12:36 PM
tRaCeYoUiNcHaLk
Mar 20, 2007 02:44 PM
darkstar1440
Nov 11, 2006 01:57 PM
komat
Jan 22, 2005 04:38 PM
extrmeboost
Mar 16, 2003 10:57 AM
