where to buy 5"-2.5" aluminum transition?
Old Jul 5, 2008 | 06:36 AM
AWOC's Avatar
Default where to buy 5"-2.5" aluminum transition?
I've looked up aluminum cones and funnels on google and I havent come up with anything that would work. I'm building an intake manifold and i need something thicker than a thin funnel.
Old Jul 5, 2008 | 10:15 AM
M3Vert's Avatar
Default Re: where to buy 5"-2.5" aluminum transition? (AWOC)
harbor freight?
Old Jul 5, 2008 | 01:10 PM
jazzpur's Avatar
how long do you want the transistion? and how thick?
Old Jul 6, 2008 | 12:51 PM
AWOC's Avatar
Default Re: where to buy 5"-2.5" aluminum transition? (jazzpur)
1/8" it can be up to 6 or 7 inches
Old Jul 7, 2008 | 11:27 AM
dfoxengr's Avatar
why so thick?
would 1/16th not work?
I could fabricate you one, but not out of 1/8th
Old Jul 7, 2008 | 03:37 PM
HiProfile's Avatar
You may have to have it machined out of a chunk of aluminum. 2.5-5" is a tall order for tubing, so for thicker metal, you may be SOL. Even if you find it, it will likely be cast.
You can usually find cutoffs on ebay for a decent price, then have a local machine shop run it through quickly. You might work out a deal since they're keeping 90% of the material as recyclable scrap.
Old Jul 7, 2008 | 04:22 PM
AWOC's Avatar
Default Re: where to buy 5"-2.5" aluminum transition? (dfoxengr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">why so thick?
I could fabricate you one, but not out of 1/8th</TD></TR></TABLE>
how do you think a .060 wall transition will support the TB and flange weight plus the vibrations from the intake tube? Too thin for my taste. I think 1/8 would be a way safer choice.
at this point I think I will get some annealed aluminum sheet and beat it in to the desired shape
Old Jul 8, 2008 | 07:10 AM
dfoxengr's Avatar
"beating" it will make a horribly ugly part.
dont you think a 1/16th tube would support it? well the transition would be stringer than that.
good luck though.
Old Jul 9, 2008 | 07:39 AM
jazzpur's Avatar
0.125 aluminum would be way to hard to form into a cone. ive made custom cones for customers before and ive found it best to use 0.080 alum...perfect comprimise. 1/16th alum is just too hard to weld without a decent amount of experience. feel free to contact me if you need help with it
Old Jul 9, 2008 | 10:14 AM
DESTROYER's Avatar
dude, its a cone. Its going to be insanely strong, similar to the "Standing on eggshells" trick. I would rock some 0.065" anyday. Aluminum isn't as weak as your making it sound.
Old Jul 14, 2008 | 08:27 AM
suprmods's Avatar
its supporting the weight horizontally, not in vertical compression.
You could always get a few transitions (availible at Burns for instance) and weld them together, 2.5-3.5 + 3.5-4.5 + 4-5 (cut at 4.5). Not sure how the cost would compare to getting a full transition machined out of aluminum stock, might not look as nice either but its an option.
Old Jul 14, 2008 | 03:51 PM
jazzpur's Avatar
Default Re: (suprmods)
heres one i did in 0.063
Old Jul 19, 2008 | 09:32 AM
Kelly.'s Avatar
I've quit using this account
edit -nevermind, i read it wrong.
Old Jul 27, 2008 | 11:35 AM
KFMRC's Avatar
2.75 (CHANGED FROM THE ORIGINAL by customer) X 5 X 6.5 LONG
delivered only welded on inside so outside welds will match rest of manifold
Modified by KFMRC at 12:26 PM 7/28/2008
mcmmotorsports
Jul 13, 2006 05:45 AM
huge230
Feb 3, 2006 10:47 AM
hybrid_vtec
Mar 30, 2005 09:33 AM
vietjdmboi
Feb 7, 2004 04:03 PM
vtec181
36
Feb 6, 2004 10:55 PM
