Problem with my turboed Z6
Old Jul 3, 2008 | 12:53 PM
90crxdriver's Avatar
Default Problem with my turboed Z6
Also posted in the forced induction forum.
I have a small problem.
I barely made it home this morning. Not getting enough air to my radiator and its trying to over heat. Going to cut more of the bumper out and wire my fan to run all the time. will see if that helps.
Also its studering really bad when I give it gas but then it will pick up and be fine. (I'm throwing a code 10 (intake air temp) and 3 (being the map sensor) Also when this happens as I'm giving it gas my AEM wideband is pegging out at 17+ in the red and then when it picks up it goes to around 11-13 in the green. This is with vary little to no boost pressure. I'm still running stock fuel system so as soon as I get my friends crx swapped and out of my garage I'm going to put my in 255lph fuel pump and fuel pressure regulator. I'm also getting dsm 450cc injectors next week.
The map was never unhooked and the only thing I did was pu a Y in for the boost gauge. Should I get a missing link and install it?
Old Jul 3, 2008 | 01:51 PM
_Keith_'s Avatar
Default Re: Problem with my turboed Z6 (90crxdriver)
How many lbs are you boosting?
Old Jul 3, 2008 | 05:53 PM
Default Re: Problem with my turboed Z6 (_Keith_)
6-7 PSI
Old Jul 3, 2008 | 11:20 PM
Smokinsax's Avatar
The Boot
I would def get your fuel situation sorted...then take it to a tuner.
jdmdc529
Feb 12, 2009 04:35 PM
90crxdriver
Jul 3, 2008 08:40 PM
foreverwefall
33
Nov 18, 2006 04:35 PM
Elite Hatch
Sep 27, 2002 02:39 PM
GSRwBOOST
Jul 19, 2001 11:03 AM
