Strange ECU fault code???
Old Jul 2, 2008 | 05:54 PM
Snow Trooper's Avatar
OG Fabricator
Default Strange ECU fault code???
Okay, I'm not honda expert so this one has me puzzled. 1991 civic 1.5 3DR hatch 5 speed. Now I've always been under the impression that the ecu flashes have been long flashes for the first digit and short quick flashes for the second digit?
With that being said the pattern I'm getting is 14 quick flashes pause 14 quick flashes pause 14 quick flashes pause,,, and so on
The sypmtoms with the car are a somewhat rough idle (the rpm hunts a little between 800-1200) then off Idle the car runs very rough, and wont take any load. By that I mean that to acctually drive the car you have to rev it to about 3500 rpm and slip the clutch and keep the rpms above that. if you try to put any load on it below about 3000-3500 rpm it wont go and wants to stall.
thanks in advance for any help!
Old Jul 2, 2008 | 06:34 PM
traxxasx's Avatar
Default Re: Strange ECU fault code??? (Snow Trooper)
14 IAC (EACV) - idle air control valve
Old Jul 2, 2008 | 06:37 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snow Trooper &raquo;</TD></TR><TR><TD CLASS="quote"> I've always been under the impression that the ecu flashes have been long flashes for the first digit and short quick flashes for the second digit? </TD></TR></TABLE>not true - ECUs for all OBD0 D-series engines have only short flashes
HdmPowered
May 4, 2009 02:15 PM
kkitz967
Dec 6, 2007 08:34 AM
flood
32
Dec 21, 2005 06:10 AM
lowcivex
May 22, 2003 09:16 AM
Eric R
Apr 25, 2003 11:20 PM
