Damn CEL!
Old Jul 2, 2008 | 02:01 AM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
Default Damn CEL!
I was swapping heat shields for my car, so i unplug the sensor and replug it after putting on the new heat shield. Now when i go start my car it has a CEL. Did me unplugging and replugging the sensor do something?
Old Jul 2, 2008 | 02:19 AM
Nbboy7's Avatar
reset the ecu
Old Jul 2, 2008 | 05:09 AM
pdiggitydogg's Avatar
No, not unless your car was on when you unplugged it.
Perhaps you cut a wire when you removed the shielding.
Check the cel before you just reset it...
Old Jul 2, 2008 | 11:57 AM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">No, not unless your car was on when you unplugged it.
Check the cel before you just reset it...</TD></TR></TABLE>
I double checked everything and I'm 100% positive i didn't cut anything. I'll be checking it today i suppose.
Old Jul 2, 2008 | 12:00 PM
riceburnerryan's Avatar
yeah just run the code, and then check everything make sure everything is still in working order, also maybe clean the plug and make sure the plug is inserted all the way...
then if all is well, reset the ECU
Old Jul 2, 2008 | 05:40 PM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
Default Re: (riceburnerryan)
So i pulled the code and its 2 long blinks and one short blink, but im not exactly sure which code that is, anyone help me on this?
Old Jul 2, 2008 | 05:45 PM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
Default Re: (PhantoM.DA)
It will just keep repeating two long blinks one short blink, two long blinks one short blink.
Old Jul 2, 2008 | 05:49 PM
z6hatchboy's Avatar
21 is the vtec spool valve or as some call the vtec solenoid. In the rear left of the head. I guess you can start by checking that out then
Old Jul 2, 2008 | 06:01 PM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
Default Re: (z6hatchboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy &raquo;</TD></TR><TR><TD CLASS="quote">21 is the vtec spool valve or as some call the vtec solenoid. In the rear left of the head. I guess you can start by checking that out then</TD></TR></TABLE>
Is something wrong with it or what? Do i need to replace it?
Old Jul 2, 2008 | 06:18 PM
OMGWTFBBQ!'s Avatar
VTEC spool valve? Did you really just call it that?
Old Jul 2, 2008 | 06:45 PM
z6hatchboy's Avatar
Default Re: (OMGWTFBBQ!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhantoM.DA &raquo;</TD></TR><TR><TD CLASS="quote">
Is something wrong with it or what? Do i need to replace it? </TD></TR></TABLE>
It may need to be replaced, check the connection if it s good then probably replace it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OMGWTFBBQ! &raquo;</TD></TR><TR><TD CLASS="quote">VTEC spool valve? Did you really just call it that?</TD></TR></TABLE>
yes i did, and if you go to a honda dealership thats what they will call it. Its honda's actual term for it, we (other people) just like to call it a solenoid because thats basically what it is, and its easy than "spool valve" (which its listed as in my service manual).
Old Jul 2, 2008 | 06:58 PM
OMGWTFBBQ!'s Avatar
Well I'll be damned.
nus_dogg
Jul 24, 2009 02:30 PM
luisda4th
Feb 24, 2008 07:43 AM
crazyguy
Aug 21, 2007 10:01 AM
civickidd99
Sep 21, 2003 01:36 PM
BoostedGSRBubble
May 10, 2002 08:40 AM
