GSR block girdle in LS block.. what all do i need..
Old Jul 18, 2002 | 08:31 PM
Speedz's Avatar
Default GSR block girdle in LS block.. what all do i need..
ok, i've seen a few LS motors built with the GSR block girdle.
i have an extra block i'm building with pr3 pistons, LS rods and crank.. everything is balanced and blueprinted. i was thinking that a gsr block girdle would be a nice addition to this block.. i've got a built LS head right now and wanna take advantage of my performance cams.. i just want it to be more reliable.
anyway, what all would i need to use the gsr block girdle in my LS block?
i work in a machine shop so i can modify whatever i need to make it work.. but i'm not sure if i need the gsr oil pan and other stuff..
i'm also thinking about the LS/VTEC after i get bored of my built LS head.
thanks
Old Jul 19, 2002 | 02:51 AM
kenji's Avatar
25 Year Member
Default Re: GSR block girdle in LS block.. what all do i need.. (Speedz)
Here is what you need:
GS-R/ITR oil pan
GS-R/ITR oil pickup
GS-R/ITR windage tray
GS-R/ITR main cap girdle
Here is what you need to do to make it fit:
You can either...
A. Machine the girdle to allow the #3 main cap, which is taller than the others, to accept the #3 main cap.
Or
B. Machine the #3 main cap so that it is the same height as the other 4 main caps. This is what I did. The GS-R/ITR main caps are all the same height so I thought it would be the right thing to do.
You also need to take off a little material of the girdle on the part where it meets the #2 main cap (I am pretty sure it is #2. I am going from memory). There are some pics floating around to demonstrate what I am talking about. Help a brutha out if you have the pic
That is pretty much it. Next thing to do is assemble the parts just like you would a GS-R/ITR block.
Good luck.
-kenji
Old Jul 19, 2002 | 03:58 AM
ninesecrx's Avatar
Default Re: GSR block girdle in LS block.. what all do i need.. (kenji)
Also you need to add the downs in between the main caps and girdle like the gsr is so the girdle can slide around. You also need the bolts....Mike
Old Jul 19, 2002 | 05:58 AM
Speedz's Avatar
Default Re: GSR block girdle in LS block.. what all do i need.. (ninesecrx)
hey thanks, so i need the GSR Main bolts as well? just for #2,#3, and #4 right?
by machining down the #3 main cap, wouldnt that weaken it? or did honda make it "bigger" because the LS motor didnt have the block girdle and that was their attempt at strengthening the LS bottom end?
if anyone has pics of this mod please post them..
thanks in advance
Old Jul 19, 2002 | 06:36 AM
CHEETAH's Avatar
thanks in advance
or you could just buy the Z10 girdle which clears the center cap. Still would need the GSR #2,3,4 bolts, pickup, oilpan and windage tray... like Milky man said.
greg
Old Jul 19, 2002 | 10:49 AM
Speedz's Avatar
Default Re: GSR block girdle in LS block.. what all do i need.. (CHEETAH)
yeah well i'm kinda on a budget so i can get the gsr block girdle for $70 and the z10 costs about what $300? give or take some.. and i'd still have to get the oilpan, and other stuff.. i'm sure the z10 is probably stronger, but i'm not going to be boosting this motor just wanna be able to safely rev to about 8200 rpm or 8600 if i go LSVTEC with typeR cams.
Old Jul 19, 2002 | 11:13 AM
BROOD's Avatar
You should Dowel the girdle to the main caps like ninesecrx said. The girdle won't do much but look pretty under that oil pan if you skip this part.
Old Jul 19, 2002 | 05:52 PM
Speedz's Avatar
Default Re: GSR block girdle in LS block.. what all do i need.. (SLPR)
ahhhh.. now i understand what ninesecrx was saying.. the "downs" kinda threw me off.. the locating pins like the head has.
thats easy enough to do.
does the gsr have those locating pins already for the block girdle? or would i need to machine the girdle as well as the main caps.?
Old Jul 19, 2002 | 09:11 PM
ninesecrx's Avatar
Haha...opps, I ment to say dowels The girdle should already have them in it and you need to drill the main caps....Mike
Old Jul 20, 2002 | 06:18 AM
Speedz's Avatar
thanks Mike,
one question.
do you guys think this is a worthwhile mod?
i mean am i just wasting time in doing this or is it really worth it?
i think it is. but i have some friends asking and so i want some others opinions.
thanks
Old Jul 20, 2002 | 08:41 AM
non-VTEC's Avatar
here's the GS-R block girdle installed onto a B20 bottom end.......it's the same as a LS bottom end anyway.......
Old Jul 20, 2002 | 03:52 PM
Speedz's Avatar
Default Re: GSR block girdle in LS block.. what all do i need.. (non-VTEC)
wow! thanks.. do you think it is worth it?
Old Jul 20, 2002 | 04:29 PM
kenji's Avatar
25 Year Member
Realistically, you will not notice the difference. But, anything you can do to make the bottom end more rigid will definitely not hurt.
If you plan on spinning your LS/VTEC or CRVTEC up to GS-R/ITR revlimits I would suggest it. It is not extremely expensive and it doesn't hurt anything.
-kenji
Old Jul 20, 2002 | 05:25 PM
non-VTEC's Avatar
yes it's worth it..........
Old Jul 21, 2002 | 06:14 AM
Speedz's Avatar
ok i know where i'm getting the gsr block girdle..
but i'm not sure where to get the gsr oil pan (its more than i wanna pay from the site where i'll get the block girdle)
what is a decent price for a gsr oil pan?
i do keep an eye on thepartstrader.com
thanks
Old Aug 16, 2002 | 05:19 PM
BR's Avatar
BR
How high would you need to be revving to make this a mod that is worth doing??
I will be running an all motor LS, but I am not going ls/vtec so would I be needing it to make my shifts between 8k-8.5k rpm's?? Realistically, with the cams that I will be running (JG 301's) I dont think that I will be shifting higher than 8k.
I am in the process of building my engine and I will be going to the machine shop to have them do their part and I wouldnt mind having everything done at once...
Later,
BR
vpower101
Jan 21, 2008 10:47 AM
russianswty
Oct 17, 2006 03:09 PM
EK FLY
Jan 27, 2005 10:57 PM
typeRSXS
Mar 24, 2004 03:54 PM
