need valve cover stud, interchangeable between d series, or exact spec
Old Jul 1, 2008 | 09:02 AM
acmoc's Avatar
Default need valve cover stud, interchangeable between d series, or exact spec
Hi,
I broke my valve cover stud on my sohc zc non v-tec, the bottom right one if you look at the engine from the front. My question is; I have a friend who has a d16y8 that he doesn't need, he told me to come pull one from that engine. Will it fit? IF not do I have to get one from a d6a6, d15. or another sohc zc, or can I just go to the dealer and order one? How much would that cost? Will they be different lengths and not allow to seal well.
Thanks in advance.
Old Jul 1, 2008 | 10:20 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: need valve cover stud, interchangeable between d series, or exact spec (acmoc)
i dont think the y8 studs will work. They kinda did the valve cover fasteners a little different on the vtec heads. They use long bolts instead of a stud and cap nut on the non vtec d series. You will probably need the a6 or other d15 non vtec style stud and cap nut setup, but to be honest, i haven't compared them side by side. its all from memory.
Old Jul 1, 2008 | 10:21 AM
wiZCo's Avatar
Stouts 'n' Scotch
A6 will work fine if it's an OBD0 ZC.
Old Jul 1, 2008 | 10:25 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">A6 will work fine if it's an OBD0 ZC.</TD></TR></TABLE>
agreed..
Old Jul 1, 2008 | 11:12 AM
Spikey640's Avatar
Default Re: (sanimalp)
any non-VTEC D series stud works
and any b series will work
im using one from a B18A1 since one of mine got lost during valve cover painting
Modified by Spikey640 at 10:03 AM 7/12/2008
Old Jul 1, 2008 | 01:31 PM
acmoc's Avatar
nope, the d16y8 one is too long.
Can I find these at the dealer?
How much should I expect to pay at a salvage yard, they were charging me 15.00 $. Not sure if that's reasonable, that place is always trying to rip me, or maybe I'm cheap.
Modified by acmoc at 5:25 PM 7/1/2008
Old Jul 1, 2008 | 02:20 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (acmoc)
whoa.. yeah $15 is retarded. you can buy brand new ones from honda for around $3 a piece.
Old Jul 1, 2008 | 04:20 PM
acmoc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanimalp &raquo;</TD></TR><TR><TD CLASS="quote">whoa.. yeah $15 is retarded. you can buy brand new ones from honda for around $3 a piece. </TD></TR></TABLE>
really, 3.00 a piece, thank you. I'm going that way instead. That place is always trying to rip me. Must be cuz I look young
Old Jul 3, 2008 | 04:00 PM
acmoc's Avatar
Default Re: (acmoc)
6.92 to be exact, got it in one day
Modified by acmoc at 5:49 PM 7/3/2008
Old Jul 3, 2008 | 04:22 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (acmoc)
ah man, should have bought it on http://hondapartsdeals.com thats where i got my $3 quote. but then there is shipping to pay too.
Old Jul 3, 2008 | 04:48 PM
acmoc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanimalp &raquo;</TD></TR><TR><TD CLASS="quote">ah man, should have bought it on http://hondapartsdeals.com thats where i got my $3 quote. but then there is shipping to pay too. </TD></TR></TABLE>
yea, shipping, I didn't mind paying the extra.
BTW, do you know ho much torque applies to the valve stud to the head
Old Jul 3, 2008 | 06:37 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (acmoc)
7 ft/lbs or 84 inch/lbs
carpenterkyle
13
Nov 7, 2012 10:04 AM
IP RACING
Dec 22, 2006 09:33 PM
liquidoblivion
Oct 18, 2006 01:54 AM
cr-rex88
Apr 11, 2006 02:58 PM
96 Ls lnTeG
Aug 10, 2003 08:46 AM
