1996 Accord 5speed. (throttle sticking, reving)
Old Jul 1, 2008 | 08:13 AM
LOLO93PRELUDE's Avatar
Default 1996 Accord 5speed. (throttle sticking, reving)
When I drive the THROTTLE seems like its sticking and not releasing out all the way when i take my foot off the gas.
it will drop back down to 700-800 rpms when i pull the petal up manually.
after engaging the throttle and lettin go it stays at 1500rpms.
any suggestions???
Old Jul 5, 2008 | 11:07 PM
99accordFX's Avatar
Default Re: 1996 Accord 5speed. (LOLO93PRELUDE)
try cleaning throttle body plate. Gets alot of gunk and carbon on plate. Also check idle air control motor. see if its dirty, try to unplug it see if problem still happens
Old Jul 6, 2008 | 11:29 AM
Schmitey's Avatar
Default Re: 1996 Accord 5speed. (99accordFX)
Agree with 99accord on cleaning things out. IAC will usually make your idle bounce all over the place but when applying gas it runs fine...so I doubt its that.
Make sure your throttle return spring is good and strong, also might give your throttle cable a good shake and flex it around. Could be rust in the cable or something too. Something somewhere is giving you resistance. Start with the easy exterior stuff before cracking the throttle body open. I'd also suggest running some SeaFoam through the intake (suck half a can through the brake booster line real SLOWLY)! Be advised it usually creates a lot of smoke the first time you run it....neighbors called the fire department on me.
Old Jul 7, 2008 | 07:52 AM
Default Re: 1996 Accord 5speed. (Schmitey)
thanks guys, the cable started to split inside the sleeve. For the mean time i just trimmed it down until i get another cable.
but it fixed the problem, runs nice again!
SpeedoKing
Aug 6, 2007 03:09 PM
Mr. JDM-GSR
Aug 29, 2005 11:33 AM
1QWKGS
Apr 3, 2005 11:52 PM
frostcivic
Oct 12, 2004 03:52 AM
miahmouse
Oct 7, 2002 09:24 AM
