92 civic CX
Old Jul 1, 2008 | 05:37 AM
Sil84's Avatar
Default 92 civic CX
i know this has been beat to death but i searched it already and could not find what i was looking for could some please point me in the right direction.
what i am looking for is info on wiring vtec which i have found but i also need to wire 4 wire o2 onto my cx also i am using an ex harness i just need to know what pins from what connector goes to what ecu pin and such.
Old Jul 1, 2008 | 07:44 AM
94EG8's Avatar
Seagull Management
Plug A (largest plug)
A6 -> heated oxengen sensor orange/black
Plug D (Second Largest Plug)
D14 -> O2 sensor white (should already be there)
D22 -> sensor ground green/white
other black wire goes to fuel injector joint connector? turns into yellow black
Old Jul 1, 2008 | 08:18 AM
94EG8's Avatar
Seagull Management
Update, it seems that "fuel injectors joint connector" is the plug on the drivers side of the car that goesn't plug into anything, its near the drivers side of the engine compartment and has a cap on the end, all the wires going into it are yellow black this should already be wired if you are using an EX engine harness
Old Jul 1, 2008 | 08:21 AM
davefromPA's Avatar
Default Re: (94EG8)
^ if you use an ex harness it will just plug in. the 92's came pre wired for vtec. plug in the harness and the ecu and done.
Old Jul 1, 2008 | 08:42 AM
94EG8's Avatar
Seagull Management
Yeah, thats what i thought too, then i read his post a second time, he already found the vtec wiring, he needed the 02 sensor wiring, which as far as i know isn't in the us cx cabin harness
Old Jul 1, 2008 | 09:26 AM
Sil84's Avatar
Default Re: (94EG8)
yeah i need the o2 pin out and the connector info but i put the wrong year model on here it is a 95. i really don't even need to run the o2 cause i have hondata.
Fliptard
Feb 28, 2012 07:11 PM
scythe88
Jan 17, 2010 05:54 AM
Origin
Jan 11, 2009 09:41 AM
06Xrunner
Jan 14, 2007 08:59 PM
kinvid22
Jun 8, 2005 01:27 PM
