Windows very slow...already read other threads
Old Jun 30, 2008 | 11:29 PM
lax1089's Avatar
Default Windows very slow...already read other threads
97 accord ex
my windows have been bad ever since i bought the car, but it is unbearable now. i keep spraying silicone grease in the channels but that seems to wear off in a few days. and i spray A LOT of grease. Also, the driver side window keeps going out of the channel at the very top (which may be unrelated). do i need to install new motors and weatherstripping or is there a cheaper fix?
Old Jul 1, 2008 | 04:08 AM
TASAuto.com's Avatar
Banned
Default Re: Windows very slow...already read other threads (lax1089)
90-97 Accords have notorious problems with window regulators and window seals. Replace the window regulators and if they still aren't as fast as your like try new window seals.
Old Jul 1, 2008 | 10:14 PM
lax1089's Avatar
Default Re: Windows very slow...already read other threads (TASAuto.com)
is it hard to install new regulators?
Old Jul 2, 2008 | 02:16 AM
fatboy1185's Avatar
Big Cat
nope just pop the panel off
Old Jul 2, 2008 | 08:45 AM
99accordFX's Avatar
First off you did good by lubing up the channels, but dont use silicone spray. Thats mainly for rubber to metal contact. Use more of a white lithium grease. Also check to make shure your chanells are lined up right. They could be alittle off causing it to bind up. Also you could try to change the motor itself.
Old Jul 2, 2008 | 10:27 AM
tburtnett's Avatar
Default Re: Windows very slow...already read other threads (99accordFX)
If you install new regulators you need to make sure you put the new ones on exactly the way the old ones were on or you may have problems getting everything to work properly. Before disconnecting the window motor I drilled a hole through the gear part of the regulator and the part behind it and put a bolt through it so the angle wouldn't change.
johm73
Oct 25, 2015 02:30 AM
santaclewes
Nov 10, 2012 04:41 PM
BBallz24
Jun 10, 2008 10:28 AM
01-0720
Aug 25, 2005 08:21 AM
RTW DC2R
Dec 24, 2002 11:03 PM
