Radius Vs. Crank pulley - Quick fix
Old Jun 30, 2008 | 10:03 PM
ketchup's Avatar
Default Radius rod Vs. Crank pulley - Quick fix
A common problem with the H-Series swap - Radius rod clearance with the Crank pulley.
The most common fix is to mount the radius rod under the LCA. We're talkin' aftermarket Traction bars here - Unless you buy one specified for your swap, at an addt'l $350 and up. I happen to like the traction bar I have, so I'd rather modify my LCA's.
First you'll need to shave off a tiny chunk of the LCA in order for one of the rear bolt to connect.
Once the radius rod is bolted to the bottom portion of the LCA, it will now sit at an angle.
After having done so, I'm wondering what can be done to the LCA to re-enforce it and to stabilize the radius rod better - Since it is designed to mount flush to the top of the LCA.
Any ideas? Would the LCA even be ok to weld?
Modified by ketchup at 11:26 AM 7/1/2008
Old Jul 1, 2008 | 08:50 AM
black0hatch's Avatar
Default Re: Radius rod Vs. Crank pulley - Quick fix (ketchup)
that looks like its gona put all the stress on the bolts insted of the lca. you might wana look into taking it to a machine shop and have them shave it flat where the bolts are going in through the bottom then have them make an exact fit spacer to sit in there where the exposed bolt is. probably should get some grade 8 bolts too.
Old Jul 1, 2008 | 09:19 AM
ketchup's Avatar
Default Re: Radius rod Vs. Crank pulley - Quick fix (black0hatch)
I have no clue where I would get grade 8 - 12mm metric bolt in 1.25 thread.
I agree, the shared stress will increase on the bolts. I was thinking of welding a metal bushing in the extra space of the exposed bolts and griding it flat with the bottom of the LCA - to replicate how it is on top.
But my question still stands, is it ok to weld on this LCA? I'm not sure if the welds would stay or if the LCA would start to crack under stress.
Old Jul 2, 2008 | 10:32 PM
4DRmafia's Avatar
This is what i might have to do if my etd ones dont clear. they siad they do but we'll see
Old Jul 2, 2008 | 10:48 PM
91redrex's Avatar
here man
https://honda-tech.com/zero...75861
the same set up i have ......
Old Jul 3, 2008 | 06:26 AM
ketchup's Avatar
Default Re: Radius rod Vs. Crank pulley - Quick fix (91redrex)
any problems with welding the LCA?
Old Jul 3, 2008 | 10:48 AM
91redrex's Avatar
no dont weld i would use a grinder to grind the surface flat then add a spacer in between....theres a thread where the guy did the same thing for the pulley problem...he did it on his full-race bars...thats what i did too..works great...
Old Jul 3, 2008 | 11:11 AM
4DRmafia's Avatar
this is what i'm going to end up doing if the etd bars dont clear.
Old Jul 7, 2008 | 11:51 AM
ketchup's Avatar
Default Re: (4DRmafia)
going to the alignment shop on tues, we'll see what they have to say about this setup.
Old Jul 7, 2008 | 05:16 PM
Crx Jimmy's Avatar
Default Re: (ketchup)
why not pm user dunkd
https://honda-tech.com/zerothread?id=1741811
https://honda-tech.com/zerothread?id=1810330
Old Jul 7, 2008 | 09:24 PM
ketchup's Avatar
Default Re: (Crx Jimmy)
yea, I already have a single belt pulley. The problem is the pulley's diameter, not width.
Old Jul 8, 2008 | 09:33 AM
welfarepc's Avatar
washers and grinder for the win
92civiceg9gsr
13
Aug 6, 2011 05:13 PM
H22AFerio
Oct 31, 2010 02:34 PM
97Prelude_SH
Nov 19, 2009 06:17 PM
whiteguyndahood
Dec 7, 2005 10:33 AM
