1991 sedan help!
Old Jun 30, 2008 | 09:24 AM
typewhatinteg's Avatar
Default 1991 sedan help!
had to replace dizzy... car is a dual point. now i got fire goin and it cranks for like three seconds then just dies.... and CEL comes on showin code 16 which is injectors.... so does this mean i have a bad injector and if so would it be the brown injector or the green injector.... i kno one is a primary and one is a secondary but i dont kno which one is which.... doesnt one crank and then the other kick in to run it??? cuz if thats the case then the one that runs it would be bad correct??? if so somebody tell me which is which or ANY advice would be nice but i just dont want to buy the wrong one
Old Jul 14, 2008 | 07:58 AM
beige89civic's Avatar
* B A N N E D *
Default Re: 1991 sedan help! (typewhatinteg)
Replace Main relay assembly located above the hood latch. Once replaced removed hazard fuse for 30 seconds to clear codes. USE A HONDA ONE no aftermarket unless you want practice replacing it. Its like 70 bucks. Check with your local dealer for avalibilty and correct part number.
Old Jul 14, 2008 | 08:03 AM
* B A N N E D *
Default Re: 1991 sedan help! (beige89civic)
39400-SH3-003 main relay assembly. This Is the correct part number I do believe. My car had the same problem not too long ago and this fixed it.
Old Jul 14, 2008 | 08:14 AM
IndySporty's Avatar
A lot of times you can try taking the main relay apart and re-soldering all the connections. It will work like new again.
Old Jul 15, 2008 | 05:54 PM
* B A N N E D *
Did you get it taken care of?
ExtraBlackRex
Oct 28, 2010 05:18 PM
winddraft
Mar 15, 2010 02:30 PM
thirteen20CRXSi
12
Jul 3, 2006 07:27 PM
draw
Jun 29, 2006 08:42 AM
4ghatch
Jan 16, 2003 02:33 PM
