HOW can i remove stock rev limit on unchipped p28 ECU>?????
Old Jul 18, 2002 | 05:53 PM
JDM CRX's Avatar
Default HOW can i remove stock rev limit on unchipped p28 ECU>?????
i need to remove my rev limiter becuase its pissing me off and the closest dood near me wants 500 for a chipped p28. does MSD make anything for this? 7200 redline with a built GSR engine isnt too coool. thanks to all that help me out.
Old Jul 18, 2002 | 07:41 PM
t's Avatar
t
Default Re: HOW can i remove stock rev limit on unchipped p28 ECU>????? (JDM CRX)
shogun power tuner
Old Jul 19, 2002 | 03:06 AM
kinesistech's Avatar
I desperately hope, for the sake of your opor Honda engine, that you are not running a gsr with and unchipped p28 made for a SOHC. You need to think much farther than just rev limiter.
Old Jul 19, 2002 | 09:45 AM
Austin's Avatar
Default Re: HOW can i remove stock rev limit on unchipped p28 ECU>????? (kinesistech)
I agree...you have much more to worry about if you're using an unchipped P28 on a "fully built GSR"
Old Jul 19, 2002 | 10:54 AM
JDM CRX's Avatar
Default Re: HOW can i remove stock rev limit on unchipped p28 ECU>????? (Austin)
its a VAFC with wideband O2 Fools, i can tune.
Old Jul 19, 2002 | 11:35 AM
Kamin's Avatar
well you need to mention that smart ***.
all we hear is fully built gsr with p28.
not i have a fully built gsr tuned with a vafc and wideband o2, id like to rremove the rev limit.
anyway, my .02 would be get hondata then have it tuned by a professional.
it will be worth the money. then you can sell the vafc. less of a thieft risk
Old Jul 19, 2002 | 11:37 AM
2point6's Avatar
Default Re: HOW can i remove stock rev limit on unchipped p28 ECU>????? (KAMiN)
but fools, he can tune...
Old Jul 19, 2002 | 01:02 PM
Austin's Avatar
Doesn't matter...it still will not be able to provide you with enough fuel for your needs...you're most likely running very lean.
Old Jul 21, 2002 | 02:50 AM
Mista Bone's Avatar
D Tranny Guru
Locash.............
http://www.locashracing.com
8500 limiter, my MSD 6AL is pilled at 7800 rpm.
bullock
Aug 19, 2004 08:14 AM
JDM CRX
Jul 18, 2002 06:51 PM
