ive asked this 3 times, still not a good awnser
Old Jul 18, 2002 | 05:35 PM
slowpokesi's Avatar
Default ive asked this 3 times, still not a good awnser
i have a b16a, with a sanden d16a air compressor i heard i could use an ac bracket from a delsol i think
anybody know exactly wich one i can use?
Old Jul 18, 2002 | 05:52 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: ive asked this 3 times, still not a good awnser (slowpokesi)
You cannot mix and match B setries brackets with D series AC compressors.
and viceversa.
This is the skinny.
You need a B series bracket for your B16. The D series AC bracket will not bolt up.
You can bolt up a D series AC compressor on a Bseries bracket, but only the two outer bolts ( the ones closer to the belt ) will line up.
The other two are quite a bit off.
You need a B series bracket and a B series AC compressor.
So you can use a Del Sol 94-95 DOHC VTEC bracket and AC compressor.
Old Jul 18, 2002 | 06:05 PM
k4ff1n3's Avatar
HA Sport makes a bracket that you can use my friend has 1 . but... do you really need AC???
Old Jul 18, 2002 | 06:39 PM
APEXI Si's Avatar
No man I don't think it will work. My friend just bought the apdapter from hasport.
Old Jul 18, 2002 | 06:41 PM
CRXBart's Avatar
Default Re: ive asked this 3 times, still not a good awnser (crx616)
WTF is A/C?
Old Jul 18, 2002 | 06:44 PM
meept's Avatar
You can't use the del Sol bracket that I'm aware of, but there is always this one:
http://www.hasport.com/M88_AC.htm
I have the Hasport bracket, but my compressor died. Now I need to find another Sanden
Old Jul 18, 2002 | 06:48 PM
WickedZ's Avatar
im using place racing... bs price for a dam adapter but it works good...
Old Jul 18, 2002 | 07:09 PM
pelotudo's Avatar
Default Re: ive asked this 3 times, still not a good awnser (blitzcrx)
110degree heat index in Central Florida today.
Screw exercising to loose weight...Just sit in my car for 15 minutes and I'll be skinny in a couple of hours. I REALLY need to get a hold of that bracket...
jb
Old Jul 18, 2002 | 08:11 PM
SqueezinEF's Avatar
Default Re: ive asked this 3 times, still not a good awnser (PeloTudo)
I gotta B16 in my EF. I have Hasport mount kit with Hasport A/C bracket. Works perfectly. I used to have an EG with LSVtec. To use the stock A/C compressor in the EG, you use an B16 Del Sol bracket. Had A/C in both swaps...
Old Jul 18, 2002 | 08:14 PM
hondacivic4g's Avatar
Um, can we say 105 degrees today and 115 on th heat index,in North Florida
The A/C was begging for an A/C!
Old Jul 18, 2002 | 09:29 PM
slowpokesi's Avatar
Default Re: ive asked this 3 times, still not a good awnser (hondacivic4g)
exactly
im in dallas, texas *aka* hell
its hot a ****, and instead of buying a jdm header i really want my ac back, i bought a fal fan
i just need to get that compressor bolted up
so a bseries ac bracked should do the trick ?
like one from an ls or soemthing like that?
Old Jul 18, 2002 | 10:14 PM
RexB16's Avatar
oh quit ur bitching, i live in the hottest state in the union and a/c still remains a mystery to me...
Old Jul 19, 2002 | 04:42 PM
CRXBart's Avatar
Default Re: ive asked this 3 times, still not a good awnser (RexB16)
Can I ask again? What is A/C?
Old Jul 19, 2002 | 04:53 PM
blacksoul's Avatar
Default Re: ive asked this 3 times, still not a good awnser (CRXBart)
I hope your joking man, but some people say "there is never a stupid question, only stupid answers"
A/C= Air Conditioning (now you hit yourself in the head and say "OHHH!")lol
[Modified by blacksoul, 1:53 AM 7/20/2002]
Old Jul 19, 2002 | 04:58 PM
Magick211's Avatar
Default Re: ive asked this 3 times, still not a good awnser (blacksoul)
Yes you can use a del-sol vtec ac bracket, Cause they had b-series motor with d-series a/c compressors
Old Jul 19, 2002 | 08:14 PM
RexB16's Avatar
i REALLY think he's joking.
Old Jul 19, 2002 | 08:32 PM
4g4me's Avatar
if you have the bracket that came with your JDM B16A whether is is the PW0 or the PR3. Two of the bolt holes will line up with your compressor. I have been running mine like this for over a year now and no problems. If you have a money tree in the back yard, go for the hasport or place racing A/C bracket. But if you want something that will function do like I did. Some might call it a N****R Rig, but it has lasted me this long. save that $200 for a compressor, because if yours hasn't gone out yet, one day it will.
Old Jul 20, 2002 | 08:31 AM
slowpokesi's Avatar
Default Re: ive asked this 3 times, still not a good awnser (4g4me)
i threw that bracket away
and i guess i threw my old ac bracket away too,
i was looking at the hasport and it looks i still need a stock pulley assymbly
dijitalbuddhist
15
Mar 3, 2014 09:33 PM
jeffhoe
May 22, 2013 05:03 PM
moco_machine
Sep 4, 2009 07:26 PM
uLikeMyPreludeSi
Oct 2, 2006 09:59 PM
Propulsion
Aug 12, 2002 10:13 PM
