bleed a brake master cylinder by the caliper?
Old Jun 29, 2008 | 03:48 PM
IntegraMastaz's Avatar
Default bleed a brake master cylinder by the caliper?
HI all,
I just replaced my brake master cylinder on my civic 92 manual, but I dont have the kit to bleed it.
WIll bleeding the four brakes do the job? (I know I will waist lot of oil)
Thx
Old Jun 29, 2008 | 04:34 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: bleed a brake master cylinder by the caliper? (IntegraMastaz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraMastaz &raquo;</TD></TR><TR><TD CLASS="quote">HI all,
Thx </TD></TR></TABLE>
first off, PLEASE DONT PUT oil in there.
or you will be doin it all again.
with that said,fill the mc, out your fingers over the ports. push the pedal til your fingers pop off of the ports. when effort is stopped, your fingers block the hole to not let air in. do this til it stops bubbling.
then bolt it up, and bleed all 4 wheels.
Old Jun 29, 2008 | 05:19 PM
Default Re: bleed a brake master cylinder by the caliper? (boostedcivicsir)
So just to confirm
1- install the mc and dont install the two brake line on it
2- use your finger to seal the two port where the two brake line will be installed.
3- fill the mc
4- pump the pedal until there is no more air buble in the mc
5- install the two brake line on the mc
6- bleed all the brakes
Am i correct? not sure about number 4
Thank you
Old Jun 30, 2008 | 05:41 AM
anyone?
Old Jul 1, 2008 | 02:45 AM
mugen mj5's Avatar
From: Where the shooting range is on the streets of LA, CA.
can someone confirm this???^^^^^^
Old Jul 1, 2008 | 03:06 AM
TotalBalance's Avatar
Default Re: bleed a brake master cylinder by the caliper? (mugen mj5)
just replace the master cylinder and connect the fuel lines to new MC, then bleed all four corners till no bubbles present.
Old Jul 1, 2008 | 04:31 AM
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugen mj5 &raquo;</TD></TR><TR><TD CLASS="quote">can someone confirm this???^^^^^^</TD></TR></TABLE>
have a friend pump the pedal til air stops coming out of the ports.
the correct way to do it is to bench bleed it with lines going back into the master til it stops bubbling there.
but if you dont have a bench bleed kit, thats the way i have done it everytime.
justforkicks
Sep 10, 2006 11:47 AM
Walterronny
12
Apr 16, 2006 08:01 AM
Mandeep
Aug 17, 2005 06:23 PM
I_love_my_HONDA
Apr 24, 2005 07:34 AM
GReddy SI
Jul 17, 2003 09:36 PM
