window regulator
Old Jun 28, 2008 | 05:31 PM
itzyaboyzeem03's Avatar
Default window regulator
my window have been off track for a while and i finally took the door cover off and unbolted the window, i realized that on side on the regulator was bent causing the window to go up crooked...can someone give me advice on how to fix this problem
Old Jun 28, 2008 | 08:31 PM
bsmith100's Avatar
Default Re: window regulator (itzyaboyzeem03)
This is a common problem. If the regulator is bent then usually it has to be replaced.
Old Jun 29, 2008 | 12:01 AM
Default Re: window regulator (bsmith100)
ok thanks, i think im just going to try and turn it into power windows, because the manual regulator is more expensive lol
Old Jun 29, 2008 | 07:27 AM
heritage36's Avatar
How did you figure auto windows would be less expensive? Usually manual regulators are very cheap, I replaced my girlfriends accord one and it was like $40 OEM. You can try spraying the run channel with silicone spray and cleaning that out too, sometimes that helps depending how dirty it is.
Old Jun 29, 2008 | 10:26 AM
d16z6_b_pirate_13's Avatar
Default Re: (heritage36)
My driver window is the same way, except i have power. Does anyone know where I can get the regulators for both doors for a 94 civic coupe
Old Jun 29, 2008 | 10:34 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: (d16z6_b_pirate_13)
http://www.autopartswarehouse....+9331
I highly recommend these guys, prices are great and they ship fast.
Old Jun 29, 2008 | 10:52 AM
lowvan86's Avatar
i think i have the same problem like this. my window started to make a loud clicking noise and the window wouldn't close all the way to the top. and my mechanic said that it might be my regulator or it might be something else
its a 98 civic EX with power windows
Old Jul 4, 2008 | 11:30 AM
bockwho's Avatar
Default Re: (lowvan86)
I have a 96 hx and my drivers side power window is hosed.
ive pulled the door skin off and keep a 10 mm just to put it back on track in the event it rains.
any good info on how to fix these. how to set up the tracts what part of the reg normaly gets bent.
I am thinking that the door skin is important and helps keep in the track any help will be help full.. the ac is inop on this car also.
Old Jul 11, 2008 | 09:26 PM
Jackie-O's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lowvan86 &raquo;</TD></TR><TR><TD CLASS="quote">i think i have the same problem like this. my window started to make a loud clicking noise and the window wouldn't close all the way to the top. and my mechanic said that it might be my regulator or it might be something else
its a 98 civic EX with power windows</TD></TR></TABLE>
i have a 98 ex also and this just happened to me. The window fell completly off track yesterday, thought i had it fixed and had to tear it all apart today again after it fell off AGAIN. Someone told me that it may be just the track, but I dont see how to replace that? Im thinking its just the regulator also, that something's bent in the front part because thats where its falling off track at. I also heard a loud clank noise a few times the past month or so, but the window worked fine at the time.
are the regulators hard to change or is it pretty basic? I have power windows if it matters in that case.
Old Jul 17, 2008 | 11:39 AM
bockwho's Avatar
Default Re: (Jackie-O)
lube the track
with liquid wrench liberly.
its kept mine running smooth for over a week now.
ScubaZ6
Feb 4, 2018 06:23 AM
headrec*
24
Apr 18, 2015 12:08 PM
jdmztrane
11
Jun 23, 2010 08:04 PM
lamboextreme
Oct 20, 2007 09:25 AM
ev13lf
Jan 23, 2006 05:32 PM
