Window regualator replacement.....
How hard is it to replace the window regulator and motor for an EM1. Driver's side? I already looked in the Helms, but it really doesn't explain anything becuase you only have that hole in the middle to work with; or should i just take it to the dealer . The problem i'm currently having is the the window keeps trying to go up (it goes all the way up, hits the top and comes back down like two inches the it repeats as long as i have the switch pressed and never completly closes it always leaves a small gap) thanks.
Re: Window regualator replacement..... (lamboextreme)
i called the dealers and they wanted $325 for the regulator and motor installed . I searched and found a DIY, but it was for a manual window not power does anyone know of a DIY for power window?
