my car shakes!
Old Jun 28, 2008 | 04:59 PM
the_dxB16's Avatar
Default my car shakes!
My problem is when i brake my wheels shake bad. i replaced my tierods inner and outer and it still shakes. how can i fix it? im thinking its my sterring box..when i loosened my innner tie rods the steering rod would move. what it broken?!
Old Jun 28, 2008 | 05:19 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: my car shakes! (the_dxB16)
When you hit the brakes? Sounds like warped rotors man.
What about the steering rods moving? Elaborate please.
Old Jun 29, 2008 | 11:12 AM
lowvan86's Avatar
Default Re: my car shakes! (mcvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec &raquo;</TD></TR><TR><TD CLASS="quote">When you hit the brakes? Sounds like warped rotors man.
What about the steering rods moving? Elaborate please.</TD></TR></TABLE>
i also think they might be warped rotors as well. i had the same problem about having warped rotors when i hit the brakes, but i found out later was because my axle wasn't pushed in all the way into the engine block causing my spindle to push out more than usual. i would double check if both axles are in your block all the way
Old Jun 29, 2008 | 01:07 PM
clubvhatchy's Avatar
yea it sounds like warped rotors i wouldve checked that first
Old Jul 2, 2008 | 09:01 PM
the_dxB16's Avatar
Default Re: (clubvhatchy)
first i had to change my innner tierods because the wheel easly wobbles witth a light nudge when jacked up. the inner tierods screw into that rod that turns the whole system. that rod moves when i tighten the innner tie rods, only on the driver side is where it moves. thats one idea of mine. i never thought of my axles and warped brakes so thanks guys ill check those out and let yall know. peace out!
Old Jul 2, 2008 | 09:10 PM
ke98248's Avatar
Default Re: (the_dxB16)
Or an alignment your toe could be way off
Old Jul 4, 2008 | 09:42 AM
lowvan86's Avatar
Default Re: (ke98248)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 &raquo;</TD></TR><TR><TD CLASS="quote">Or an alignment your toe could be way off</TD></TR></TABLE>
could also be a possibility
Old Jul 4, 2008 | 09:44 AM
H.A.R.T B18C1EG6's Avatar
Default Re: (lowvan86)
warped rotors ftl
Old Jul 4, 2008 | 10:00 AM
.illwhitecoupe.'s Avatar
Default Re: (H.A.R.T B18C1EG6)
Yea most likely your rotors
Old Jul 30, 2009 | 07:33 PM
the_dxB16's Avatar
yup it was my rotors new ones from autozone fixed it haha thx peeps!
extensioncordy
Jun 2, 2006 08:56 AM
Devo94ac
Jan 31, 2006 08:52 PM
JDM_SOHC
12
Dec 1, 2005 09:33 AM
GsR-Freak
Mar 5, 2005 11:02 AM
civic_speed99
16
Oct 16, 2004 07:03 PM
