ctr pistons in b16a1?
Old Jul 18, 2002 | 03:41 PM
endob16a's Avatar
Default ctr pistons in b16a1?
i am looking at purchasing some b16b pistons for my first gen b16a, and i was just making sure they would fit. my friend was wondering if the bores on the 2 differing blocks were the same. also what will i need to do this swap? i know i need rod bearings, rings, wrist pins, but what else? thanks
Old Jul 18, 2002 | 05:30 PM
RexB16's Avatar
Default Re: ctr pistons in b16a1? (endob16a)
yes they will fit, all b-series, save for the b20b/z are the same 81mm bore. howover i would recommend having your bores cleaned up by goign .25mm over (this can be done by any decent machine shop) and going with .25mm over pistons. while you have the bottom end apart you have the chance to have your crank polished and balanced, to replace rod and main bearings, rod bolts, and head bolts. i would not advise you to use your old parts when putting your motor back together, but u surely can if you want they should work just fine. just remember there is a cheap way to do things and then there is a proper way, sometimes they agree and sometimes they dont.
Old Jul 18, 2002 | 06:23 PM
bryant's Avatar
you have to shave a part off the rods too. Do a search it has been talked about many times.
Old Jul 18, 2002 | 06:33 PM
CRXBart's Avatar
Default Re: ctr pistons in b16a1? (CR-X)
Yes you have to machine 1mm off both sides of the rod. The B16B piston has a narrower opening for the rod then the b16a has. I have these pistons in my motor, with stock rods. It runs great but prepare to run race fuel. I mix 4gal Cam 2 110 octane race fuel to 6gal 92 octane. I highly recomend running some kind of engine management along with this setup. I am running a VAFC with 450cc DSM injectors. I found a ton more power once I adjusted the VAFC. It felt like tremendous waste of money before I adjusted it. I haven't dynoed it yet but after I get the head done this winter it will see the dyno next spring.
[Modified by CRXBart, 10:33 PM 7/18/2002]
Old Jul 18, 2002 | 09:18 PM
endob16a's Avatar
thanks for all the help everyone!
Old Jul 18, 2002 | 10:15 PM
RexB16's Avatar
whoops, i forgot the most importand part... for that i give myself this----->
Master23
Apr 21, 2006 03:18 PM
Dropspeed
Sep 4, 2004 05:15 AM
mist sITR
Feb 25, 2003 10:16 AM
B16ACRX
May 16, 2002 11:02 PM
