Transmissio/Drive shaft seal leaking
Old Jun 28, 2008 | 12:00 PM
ku's Avatar
ku
Default Transmissio/Drive shaft seal leaking
hey guys
just replace a clutch on a 96 spec jdm dc2
with a oem exedy replacement
went for test drive
came back
oil sprayed all down the exhast
i've decided its the shiftlinkage seal where it attatched to the gearbox
or the driveshaft axle seal needs replacing?
there is tiny drips of oil on shift linkage
not sure which 1 is causing the problem
anyhelp would be great guys
cheers
Old Jun 28, 2008 | 02:27 PM
neo_'s Avatar
Default Re: Transmissio/Drive shaft seal leaking (ku)
It's most likely your driveshaft seal that got worn out from taking the axles out or putting them in. And yes, I had oil around area of the shiftlinkage seal and shift linkage when my axle seal went out.
I haven't seen those shiftlinkage seals go out often, most likely your axle seal.
Old Jun 29, 2008 | 07:10 AM
ku's Avatar
ku
thanks
do you have the part number for the axle seal
so i can get 1 from honda
or get 2 seals and change both seals?
Old Jun 29, 2008 | 11:18 PM
Aquafina's Avatar
Shift rod seals don't go out very often on newer Hondas.
Best to replace both axle seals at the same time. I don't know the part numbers (each side is different so you will need to order both seals.
Old Jun 30, 2008 | 05:57 AM
walker111's Avatar
Default Re: (ku)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ku &raquo;</TD></TR><TR><TD CLASS="quote">thanks
or get 2 seals and change both seals?</TD></TR></TABLE>
91205-PC9-711 Passenger
91205-PL3-A01 Drivers
Old Jun 30, 2008 | 08:13 AM
ku's Avatar
ku
thanks
does anyone also know the shifter linkage seal?
thanks
Old Jun 30, 2008 | 08:50 AM
walker111's Avatar
Default Re: (ku)
91215-689-013 OIL SEAL
dodt
Mar 15, 2015 06:40 PM
TNSteel
Sep 3, 2013 09:35 PM
james d
Transmission & Drivetrain
May 1, 2013 07:21 PM
lunareg
Apr 9, 2011 09:27 PM
aaronfelipe
Mar 24, 2009 03:27 PM
