dizzy wont fit!!!, searched need help asap
Old Jun 28, 2008 | 06:02 AM
egmatt93's Avatar
Default dizzy wont fit!!!, searched need help asap
like the topic says my dizzy will not fit into the head. I put gsr cams in a 00 B16a2 and this is my only problem.
to be more descriptive, its the stock b16 dizzy. the bottom 2 bolts are in but the top does not sit flush with the head... anyone have any idea or tips. need info asap please!!!
Old Jun 28, 2008 | 06:50 AM
pdiggitydogg's Avatar
Sounds like youre 180* off..........
Old Jun 28, 2008 | 07:00 AM
egmatt93's Avatar
Default Re: (pdiggitydogg)
ive tried it both ways of course and nothing. i even tried a gsr dizzy and it sits the same way. could the cam be positioned wrong, because from what ive hear and read up on is that gsr cams fit in a b16 just fine
Old Jun 28, 2008 | 07:33 AM
You have spun the key, right? Not the entire dizzy?
Always start with the simple stuff...
It should fit fine, yes.
Old Jun 28, 2008 | 08:47 AM
egmatt93's Avatar
yea i spun just the key, what else could make it not fit in all the way?
Old Jun 28, 2008 | 09:08 AM
egmatt93's Avatar
Default Re: (egmatt93)
anyone have any other ideas, im open to any opions or suggestions
Old Jun 28, 2008 | 09:11 AM
hotrod99's Avatar
hehehe...i had this same problem when i was putting my motor together,ya just gotta keep trying it will fit
Old Jun 28, 2008 | 10:47 AM
The only way this can happen is if your keys arent lining up.
Inspect the cams, be sure nothing is in the way.
Have you tried fitting the dizzy with the valve cover and primary cam cap removed?
You could see where its binding then
Old Jun 28, 2008 | 12:31 PM
egmatt93's Avatar
ill give it a shot, iif anyone else has any ideas feel free to post em, but if i dont get it within the next few days, im just goin back to my b16 cams.
Old Jun 30, 2008 | 05:03 AM
egmatt93's Avatar
Old Jun 30, 2008 | 05:05 AM
egmatt93's Avatar
so i talked to the handjob who sold me the cams, and he said when he had them he tried to put to dizz in backwards , he made 2 grooves where the dizz key goes in, grinded them off, and my dizzy fit in like a charm, thank you guys for your help, especially you pdiggity
d16z6305civic
14
Dec 29, 2010 01:24 PM
Daboyu978
Honda Fit
Jan 9, 2009 11:03 AM
Phynesse
Honda Fit
May 7, 2006 08:56 PM
2civic3
Mar 21, 2006 05:06 PM
MADEINIRAQ
Aug 22, 2002 12:10 PM
