car bogging, and has a hard time starting up
My car breaks a lot!
ok so i just put in a b20vtec and the car was running great, but the other day i was driving and the car died, so i pulled over and tried to start it back up but all i heard was a cranking sound, i called my friend up who brought over his dizzy, and my car started right up so i drove it home. so now i got a new dizzy from my cousin and put it in, the car seems to have a hard time starting up, and it bogs really bad at all rpms, also when i rev it up a little bit to around 3k in my drive way the rpms drop way to low and the car shakes like its gonna die.
any help would be great thanks for looking guys
check your compression may sound weird but my friend had the same problem and turned out one of his cylinder was bad. same setup that u have b20v and was just built at the time too.
aside from the starting issue..my car was bogging down i replaced the throttle body so i could get map and tps sensors that were good, cleaned out IACV and cleaned out the FITV. FITV is on the throttle body. cover is brass looking with two screws. take it off clean it out and tighten the center up and then maybe your **** will run better. theres plenty of threads talking about fitv and iacv if you think that may help your situation.
hwani.h22a.
Feb 23, 2006 09:41 AM
brizjuan
10
Oct 14, 2005 09:40 PM
