HELP MY CAR WON'T START!
Old Jun 27, 2008 | 08:30 AM
xSoylentGreenx's Avatar
Default HELP MY CAR WON'T START!
Hey, so, my 1989 crx stopped starting. It'd been needing to turn over a few times before it started for a while, I had been trying to figure it out, when it suddenly stopped altogether. I originally thought it was the ignitor, and the ecu blinking code told me it was either the coil or the ignitor, I put in the brand new distributer and nothing changed. It turns over, just doesn't catch. Please, if you have any ideas reply, I would really appreciate any suggestions!! Thanks!!
~H
Old Jun 27, 2008 | 09:45 AM
vtecb18c's Avatar
Default Re: HELP MY CAR WON'T START! (xSoylentGreenx)
possibly a bad fuel pump
Old Jun 27, 2008 | 12:50 PM
Default Re: HELP MY CAR WON'T START! (vtecb18c)
Nah, I replaced that a while back when it first started having issues, didn't change anything, thanks for the suggestion tho!
Old Jun 27, 2008 | 06:43 PM
vtecb18c's Avatar
are you getting spark? might be your ecu or something in your wire harness
Old Jun 27, 2008 | 08:18 PM
vtec_ef8's Avatar
three basic things to make a car run : air, fuel, spark. make sure you have all those and it should run. check spark first, pull a plug out and leave it attached to the wire and crank it to see if it sparks, if you got that make sure there fuel pressure.
Modified by vtec_ef8 at 2:02 PM 6/28/2008
Old Jun 27, 2008 | 10:42 PM
Default Re: HELP MY CAR WON'T START! (vtec_ef8)
I know what it takes to make a car run, I appreciate the run down though. Ive checked the spark, there is none, which is why I went the distributer route, which is also what the ecu told me to do, so Im assuming the ecu isnt shot, also cause its turning over, just not starting. Might be something in the wiring harness, any idea how to track that down? Thanks so much for the suggestions, I really appreciate the help!
Old Jun 27, 2008 | 10:50 PM
Janos Lin's Avatar
Are you still getting codes?
How are your grounds? Especially the one for the head. It goes from the valve cover stud, to the valve cover itself, then to the front left radiator bracket.
Janos
Old Jun 28, 2008 | 10:18 AM
Default Re: HELP MY CAR WON'T START! (Janos Lin)
yup, grounds are good, ground from valve cover is good. The code Im getting is 6 then pause then 15, any ideas? i know 15 is ignitor/coil, but thats not the problem, thanks guys!
Old Jun 28, 2008 | 12:58 PM
Janos Lin's Avatar
That's the ECT sensor thats on the side of your head.
That's suggestive of a bad ground somewhere. What about the one on the thermostat housing, and the one on the transmission? Are those there?
How do you know the one for the valve cover is good? They can be broken inside, or damaged enough that they show continunity, but fail when a load is placed on it.
Janos
Old Jul 2, 2008 | 12:10 PM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xSoylentGreenx &raquo;</TD></TR><TR><TD CLASS="quote"> I originally thought it was the ignitor, and the ecu blinking code told me it was either the coil or the ignitor, I put in the brand new distributer and nothing changed.
~H</TD></TR></TABLE>
Did you change the wheels too?
wth.
ECU says coil or igniter... replace those yet (or test them)?? =P
whytry2002
Oct 19, 2010 08:44 PM
El Boricua
Apr 7, 2008 04:13 PM
streetjdmrex
Aug 8, 2007 12:59 AM
masterp
Dec 5, 2006 02:26 PM
vietjdmboi
Mar 8, 2005 06:33 PM
