weird whistling noise.
Old Jun 27, 2008 | 07:34 AM
Adankid's Avatar
Default weird whistling noise.
Not sure if it is normal, but in 2nd gear, once i reach about 3-3.5k it starts to make a weird whistling noise.
it also does it in 3rd, but not as loud as in 2nd.
Does anybody else have this problem?
vehicle: EK with a GSR
Old Jun 27, 2008 | 07:43 AM
thrust's Avatar
any more information you can provide? we have very noisey engines and it can be a lot of things. throw out bearing, fuel injectors, vaves need adjusting etc...
Old Jun 27, 2008 | 07:44 AM
jus_spooln_wicha's Avatar
Default Re: weird whistling noise. (Adankid)
its your throttle body most likely.. i had the same problem with my gsr.. it would whistle around 2500-3500 rpms .. i swapped the throttle body and its good to go now.. granted it probobly could be a number of things.. but that was my issue and yours sounds similar. good luck
Old Jun 27, 2008 | 07:54 AM
kyorishin's Avatar
whisting like a sucking noise, thats just your intake its more noticable on bserise
Old Jun 27, 2008 | 01:48 PM
Adankid's Avatar
ahh crap.
is that hard to fix?
the throttle body piece?
and how much would it cost?
i wouldn't know, this is my first car. therefore, i am a great noob.
and im hoping its just the intake.
Old Jun 27, 2008 | 01:53 PM
team_exceed's Avatar
Default Re: (Adankid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adankid &raquo;</TD></TR><TR><TD CLASS="quote">ahh crap.
and im hoping its just the intake.</TD></TR></TABLE>
it most likely is. They all tend to do that.
Old Jun 27, 2008 | 02:00 PM
OMGWTFBBQ!'s Avatar
I have a Type R in my EK with a cold air intake, and under partial throttle my intake will whistle loud enough to make it hard to hear someone talking in the car.
Old Jun 27, 2008 | 02:43 PM
gsr96cx's Avatar
what kind of whistling noise is it? metal like or air like whistle?
Old Jun 27, 2008 | 02:58 PM
Default Re: weird whistling noise. (gsr96cx)
to be honest with you..changing the throttle body is really easy to swap out.. as far price goes it really depends on were you buy the throttle body from.. plus if you buy a used one.. you never know what kind of condition it could be in ..and it has to be a gsr throttle body.. if you change the intake manifold to a b16 or something you could use an LS b16, or type r if you wanna spend some money..
Modified by jus_spooln_wicha at 4:04 PM 6/27/2008
Old Jun 28, 2008 | 05:59 AM
wondersparrow's Avatar
I have a whistle that comes and goes too. its actually a torque leak from my exhaust. it leaks at the front side of the cat at ~1/4 - 1/2 throttle.
Old Jun 28, 2008 | 07:01 AM
Civic_07's Avatar
my intake makes a high spooling sound in higher rpm:O...but its not turbo
almostjdmeg
Nov 13, 2019 12:12 PM
civicgsr116
Nov 22, 2007 08:47 AM
rsf-g
May 9, 2007 02:22 PM
sslude
Feb 17, 2003 05:14 PM
crxtreme27
Aug 31, 2002 11:49 AM
