Honda S2000 Honda S2000
pump assist air?
Old Jun 26, 2008 | 08:44 PM
MADBADGER's Avatar
Default pump assist air?
inside the left front bumper is device labeled pump assist air on my 2000 s2000. what the heck is this.. its getting in the way of my turbo install. can i do away with this?
Old Jun 27, 2008 | 04:18 AM
papa5murf's Avatar
Default Re: pump assist air? (MADBADGER)
It's the secondary air pump. You do not need it. However, if you are using a stock ECU, you will throw a CEL.
Old Jun 27, 2008 | 04:43 AM
Chris.'s Avatar
Honda-Tech Order of Merit
Default Re: pump assist air? (papa5murf)
if you're running a stock ecu with a turbo, the secondary air pump is the least of your problems
Old Jun 27, 2008 | 10:16 AM
MADBADGER's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf &raquo;</TD></TR><TR><TD CLASS="quote">It's the secondary air pump. You do not need it. However, if you are using a stock ECU, you will throw a CEL. </TD></TR></TABLE>
is there anyway i can fix the check engine light and have it off?
Old Jun 27, 2008 | 10:17 AM
papa5murf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MADBADGER &raquo;</TD></TR><TR><TD CLASS="quote">
is there anyway i can fix the check engine light and have it off?</TD></TR></TABLE>
No, unless you keep the unit in.
Old Jun 27, 2008 | 11:11 AM
MADBADGER's Avatar
No, unless you keep the unit in. </TD></TR></TABLE>
does it throw a check engine light or is it the EPS thing i now see on the dash?
Old Jun 27, 2008 | 11:22 AM
papa5murf's Avatar
It throws a CEL.
Old Jun 27, 2008 | 01:05 PM
Firstoost's Avatar
Remove it, unless you wanna hear this kick *** high pitched whistle while the car warms up.
Old Jun 27, 2008 | 02:13 PM
MADBADGER's Avatar
Default Re: pump assist air? (Firstoost)
I didn't want the check engine light on so i couldn't simply remove it.. it was getting in the way of the pipping from the intercooler
so this is what i did, I removed the metal "frame" that latches the device to the car, I cut some plastc out and squished it in, but i had to unhook the hose that goes to the intake. So i got one of the really tiny air filters and stuck it on the end of that opening and problem solved. but the device is just sitting on the inside of the bumper not really attached to anything. But no CEL
Old Jun 27, 2008 | 02:22 PM
GRAF-FITI's Avatar
* B A N N E D *
ghetto rigged? yes
do you have to worry about a stupid light that isn't a big deal to look at? no
Old Jun 27, 2008 | 04:57 PM
Firstoost's Avatar
If you have a check engine light from it you're not running the proper fuel management. My AEM has not produced any CEL's after completely removing it.
trepteg
Honda S2000
Aug 24, 2009 12:36 PM
ma_rio44
Honda S2000
Nov 5, 2008 06:32 PM
veilside_s2k
Honda S2000
Oct 13, 2007 06:20 PM
sounguy787
Honda S2000
Oct 12, 2006 12:40 PM
AKS2K
Honda S2000
18
Nov 9, 2004 10:14 PM
