no power to my distributor
Old Jun 26, 2008 | 07:31 PM
the barber's Avatar
Default 93 DEL SOL no power to my distributor
I just bought a 93 del sol and some one had cut the wires on both sides of the plug leading to the distributor. I straight wired them and the car was not getting any spark so I disconnected them and checked them with a meter and as far as I could tell there is no power going to the distributor from the wiring harness. In addition to that I cant hear the fuel pump kick on. Its possible that whoever cut the wires could have done something else and I am at a loss. Can someone please give me some direction
Modified by the barber at 1:54 AM 6/27/2008
Old Jun 26, 2008 | 07:48 PM
7601chexplicit's Avatar
Default Re: no power to my distributor (the barber)
check the fuses under the steering wheel, there should be one for "ignition coil"
Old Jun 26, 2008 | 07:55 PM
the barber's Avatar
Default Re: no power to my distributor (7601chexplicit)
I have been under there and cant tell one from the other ther is no diagram to go by
Old Jun 26, 2008 | 07:57 PM
the barber's Avatar
is it a relay or fuse
Old Jun 27, 2008 | 01:08 AM
on my 2000 si it was a fuse....check them one at a time if you have no diagram...some needle nose pliers make it easier
tfsmith8
13
Apr 22, 2025 07:01 AM
JforJonathan
Dec 12, 2004 03:16 PM
JDMBB2
Jan 25, 2004 09:17 AM
