Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Issue With Headlights, need Help
Old Jun 26, 2008 | 04:16 PM
Killtodie's Avatar
* B A N N E D *
Default Issue With Headlights, need Help
So... I had crappy HIDs that last night one of the converters burned out.
Today I ripped it all out, put in regular bulbs [all the original wiring is still there]
The bulbs work fine.
Cept here is the problem that started when one of the converters went out.
With the HIDs my amber turn signals never lit up. The parking ones did. After the left HID went out, the Amber turn signal lit up. The right one still doesnt.
Now with stock bulbs, the left turn signal lights up along with the parkin light, but the right one doesnt light up at all.
Also, my rear right top break light stays on the whole time.
on top of that when I turn on the parking lights or lights my left turn signal on the dashboard lights and stays light. When I try to use the left turn signal, my whole dashboard blinks. Right turn signal works fine.
I checked all the fuses, that all appears to be fine.
Lights work, hi beams work, break lights work. Just right break light always on, left turn signal not working when parking lights/headlights turn on.
I was diging around and also found this lose wire that was hanging there. I cant see if there is another one on the other side, but maybe this leads somewhere
this is on the right side.
Old Jun 26, 2008 | 10:09 PM
DynastyRacer22's Avatar
i think thats the plug that your foglights plug into..i found that same plug in my car also on the pass. side
Old Jun 26, 2008 | 10:30 PM
wickedbautista's Avatar
Default Re: (DynastyRacer22)
that wire looks like the tach wire..
Old Jun 26, 2008 | 11:36 PM
Killtodie's Avatar
* B A N N E D *
ok. so what else happens
light off. left turn signal on front doesnt work, on rear the whole light lights up, break, side marker. everything.
with lights on left turn signal gives me hazard lights on the back.
right turn signalworks fine
same thing happens when i set the alarm on the car. but today for a few times it worked fine. like I was setting the alarm, i saw em light up normaly a few times then it went back to its thing.....
Old Jun 27, 2008 | 03:46 PM
Killtodie's Avatar
* B A N N E D *
is this my harness? or??
rawrjaay
Aug 24, 2022 02:38 PM
OneFire
12
Jun 30, 2011 06:38 PM
simplypinoyy
Jul 12, 2008 11:59 PM
bmxer
Feb 2, 2008 07:00 PM
